  New Posts New Posts RSS Feed: Water Tank Fill
Topic ClosedWater Tank Fill
jeffreypenhall View Drop Down
Direct Link To This Post Topic: Water Tank Fill
    Posted: 15 Sep 2016 at 9:33am
I recently went to a camp ground and hooked up a hose for water. After about 3 hours I noticed my previously empty water tank was now full and water slowly poured out the water tank fill inlet. Any reason why the water tank would fill up while using city water?
R-POD is R-PAD
Black Ford F350
Oregon License "HQRSE"
Direct Link To This Post Posted: 15 Sep 2016 at 9:42am
Let me summarize what I have read about this situation. I have not experienced it myself.
A stuck check valve for the fresh water tank to water pump can cause this. The solution I have read is:
1. disconnect the city water connection.
2. (since your tank is full) Turn the pump on.
3. Open faucets to let the water run and (hopefully) clear out whatever is blocking the check valve. You may need to do this a few times.
4. Turn off pump.
5. Reconnect city water hose. If the tank does not fill and overflow, you have cured the problem. If not, then you may need to repeat the above steps.
6. If that still does not work, then you may have a bad check valve.
Hopefully, it will work.
CharlieM View Drop Down
Direct Link To This Post Posted: 15 Sep 2016 at 9:50am
Note that the check valve involved is physically part of the pump. If it remains defective the pump will not be able to maintain pressure and will cycle frequently even when no water is being used.
