F 150, Need Equalizer Hitch |
Post Reply | Page <12 |
podvader
Groupie Joined: 22 Jan 2015 Online Status: Offline Posts: 63 |
Topic: F 150, Need Equalizer Hitch Posted: 20 Sep 2016 at 4:25pm |
I purchased the e2 for my f-150 to tow my 183g. I decided to drive my 7 hour trip without it as it was pouring rain and i didn't want to assemble it in the rain. Long story short, it towed like a dream. I am going to return my e2 and just get a sway bar.
Everything plays a part and you will never regret having a WDH. Your towing comfort level, specific setup and how you load the pod will all play a factor in whether you NEED a WDH.
Hunter74
Newbie Joined: 09 Mar 2016 Online Status: Offline Posts: 36 |
Posted: 20 Sep 2016 at 2:47pm |
same with me as techntrek. I tow with a 1500 Ram Hemi I use a Fastway E2 equalizer. By the specs of my truck I shouldn't need one either, but I towed once with out it, and hit wind and I could see the trailer moving around behind me, was very unsettling. I have never not towed without it since. Even to the dealership which is 20 minutes away, I always use it.
Posted: 19 Sep 2016 at 8:35pm |
Welcome. I bought a WDH when I towed my pod with a Sienna. Then I bought a Suburban, which by the numbers doesn't need one. I found on the first trip out that the ride quality was much better with it so I always used it.
dayman
Newbie Joined: 07 Apr 2016 Online Status: Offline Posts: 16 |
Posted: 19 Sep 2016 at 8:18pm |
I have the same tow vehicle except with a v8. Traded after a few trips with a Jeep Wrangler jk that felt strained. I just have the anti sway bar (one side) and have had no issues, even with long hauls (couple hundred miles) at interstate speeds. Congrats on the pod and truck!
Posted: 19 Sep 2016 at 8:14pm |
Sway control? Absolutely!
Equalization? Maybe. It depends on the suspension of your F150. If you hitch up your R-Pod and notice that the back end squats and the front end lifts, then some form of weight distribution hitch, whether the Equal-i-zer, the E2, or the Andersen no-sway is something I would think you would want. Any of the three I mentioned would combine both WD and sway control. Since you say it came with the controller built-in, you may want to watch this video from Ford. |
Corvettedave
Newbie Joined: 18 Sep 2016 Online Status: Offline Posts: 2 |
Posted: 19 Sep 2016 at 8:04pm |
Hi All, just purchased a 2016 178 R pod. Had a Honda Pilot as TV, but after reading here, we went out and bought a 2013 F150 Supercrew 4wd, with the 3.5 L Eco Boost. The F150 has a trailer package with electric brake control, anti trailer sway control and proper 7 pin hook up. Is it necessary to also have an Equalizer hitch or similar. Dealer has a single arm sway control bar that they say is enough. Your thoughts on this would be helpful.
