Quick How To: Installing BAL Hide-A-Spare |
Post Reply | Page <1 2345> |
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6285 |
Topic: Quick How To: Installing BAL Hide-A-Spare Posted: 19 Jul 2018 at 4:05pm |
Remember that the tire gets lowered as well as getting pulled out. There will be room. I had one mounted on our RP179. The HR's 15" wheel isn't that much bigger than the 14" wheels on ours. I don't have it mounted now because I used that space for my ladder and sewage hose holders and put the tire on its original mount. It was okay when I had it there. Like you, I was concerned about space, but realized that it was a non-issue as soon as I saw that lowering it would give plenty of clearance for the stabilizer.
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2627 |
Posted: 19 Jul 2018 at 5:16pm |
Did you turn/rotate your rear stabilizers? In the back of our HRE, the rear stabilizers are mounted at a (roughly) 45 degree angle. They seem like they would seriously encroach on the space occupied by the hide-a-spare and spare tire.
Posted: 19 Jul 2018 at 8:14pm |
No, the midwest edition has the same layout for the stabilizers as the HRE. When the BAL is mounted, the tire sits toward the center of the R-Pod. If the tire were square, it would be a problem. The stabilizers clear the tire because it is not near them when it is centered in the space between the steps and the crossbar that supports the original spare carrier.
GlueGuy
Posted: 20 Jul 2018 at 8:22am |
I will lay it out this weekend. The vertical space will be close. The tire is 9" wide. The frame is 4" tall, and the BAL allows 6-1/2" on one side and 6" on the other (so 10 to 10-1/2 inches). That means we "should" have 1 to 1-1/2" clearance for the tire.
tony rpod 180
Groupie Joined: 18 Aug 2018 Location: Arkansas Online Status: Offline Posts: 75 |
Posted: 18 Aug 2018 at 5:38pm |
i have a 2018 R pod 180 Hood River Edition and tried to install the spare tire rack. The width of the 15" tires prevented the mounting of the locking bracket to the frame. I needed at least 2 more inches to mount the bracket to the camper frame. I didn't realize this until AFTER I cut both telescoping rods on the BAL rack so it would fit between the frame rails. Now i'm stuck with a 35lb paper weight.
GMC Canyon/RPoder
crw8sr
Senior Member Joined: 12 Oct 2017 Location: Omaha Nebraska Online Status: Offline Posts: 328 |
Posted: 18 Aug 2018 at 6:02pm |
Get creative and extend the attachment points with some metal plate.
Chuck & Lyn
Izzy, Morkie. RIP Zoe Joy & Gracie, Yorkie 2018 R Pod 190 2019 Traverse In moments of adversity;when life's a total wreck, I think of those worse off than me and really feel like heck. |
AZ Pete
Newbie Joined: 01 Jul 2017 Location: AZ Online Status: Offline Posts: 5 |
just take the mounting plates to a welding shop and have them extended about 2". That is what I did to mount mine on our 180
tony rpod 180
Posted: 18 Aug 2018 at 7:13pm |
We thought about that, however we decided the rack would hang too close to the ground for our comfort.
GMC Canyon/RPoder
AZ Pete
Posted: 18 Aug 2018 at 7:29pm |
It still has plenty of ground clearance
Posted: 18 Aug 2018 at 9:20pm |
If you look at it, it does not hang below the level of the steps (on our 179 it didn't). Anything that would take out the BAL Hide-A-Spare would also likely take out the steps with it.
