Bought a 179, now what do I need to buy? |
Post Reply | Page 12> |
Author | ||
Bugout
Senior Member Joined: 01 Jan 2017 Location: S caroline Online Status: Offline Posts: 117 |
Topic: Bought a 179, now what do I need to buy? Posted: 12 Feb 2017 at 3:04pm |
Ok just ordered camco circuit analyzer 65.00 off Stephen h post great price thank you I've been looking at these but 110.00 was to step ps go ahead and get the 50 to 30 dog bone I've used mine two times in my first year
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Blue Highways
podders Helping podders - pHp Joined: 20 Sep 2016 Location: NC mountains Online Status: Offline Posts: 84 |
Posted: 12 Feb 2017 at 1:41pm | |
An adaptor note:
Re: Sailor323 on getting the adapter so you can plug into 50 amps (male on the 50 amp side and female on the 30 amp side)
Sometimes, arriving at a popular camping facility, (or pulling in a bit late)....it may get reported by the office that all the 30 amp sites are occupied, but they have remaining "Motorhome pull-through" spots available (set up mostly for large 50 amp motorhomes.) With the "dogbone" adaptor for your 30 amp needs, you can go ahead and take one of those remaining sites, rather than leave tired to drive onward to some other campground. I also generally use a household socket wiring tester (under $10, with orange/red LED indicators) to check for faults or poor connections in the electrical post's outlets (it's attached to 110 end of the appropriate adaptor. This paid off once so far: I got a funky flicker (on and then off for good) reporting back from the 30amp receptacle, but testing the 50amp proved strong and correct. It was secure to just pull power for the R-Pod from the 50amp side (into 30 amp via the dogbone) that day. Probably won't ever happen again exactly this way, but it's good to always carry this adaptor. If you need one, some campgrounds will sell one to you, (but it won't be at the nice discount box store price). (PS: We test-drove the Mazda once in early 16, and it was one stout SUV / truckster. The body was super tight and rigid and the engine HP was fairly up there. I'm guessing that it would tug a POD okay if you're diligent in clicking off the overdrive as needed, and you had an equalizer as a little extra protection. -b |
malkbean2
Groupie Joined: 31 Jan 2017 Online Status: Offline Posts: 80 |
Posted: 10 Feb 2017 at 1:10pm | |
How did that Mazda turn out for towing the 179.
Can you go long distanvce at interstate speed? Have you gone over mountains? |
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 16 Nov 2016 at 7:41am | |
I have been places where the 30 amp plug didn't work so I plugged into the 50A plug. Be prepared! I also stayed once at a CG where only 50A was available (they provided an adapter) |
Posted: 15 Nov 2016 at 10:25pm | |
Thank you for the clarification. I will concede that a 50A to 30A adapter could be useful. We have a Camco circuit analyzer which I plug in to make sure the circuit is working properly and is properly grounded before connecting the R-Pod. That is another item that would be good to add to any list as it also provides surge protection.
Posted: 15 Nov 2016 at 9:19pm | |
Since 1986, I've needed a 50-to-30 adapter only 3 times. Twice the site was 50-amps-only (which I've seen a few times), once the 30-amp outlet was impossible to plug in to. Since the 30 amp outlet is used the most you can run into bad outlets, or mis-wired outlets, bad grounds, etc. and the next best option between the 50 or 20 amp outlets is the 50, if you don't want to manage your loads.
For the little bit of money a 50 to 30 dogbone costs, I recommend getting one. Edit: I took a while typing this (melting ice cream) so I see some of these points have been mentioned. No reason to move when you can use the 50 or 20 - assuming they are wired correctly. Often a bad ground is found on all 3 outlets and then you do need to move, but be careful because I've seen bad grounds on multiple pedestals in a row, so check before moving. |
Posted: 15 Nov 2016 at 9:00pm | |
The better option there is to report it to the office so the problem can be fixed and/or so you can move to a site which has a working outlet. Just using a workaround does not fix the problem and it also leaves it for the next person. |
NoDak
Newbie Joined: 11 Aug 2016 Online Status: Offline Posts: 26 |
Posted: 15 Nov 2016 at 8:52pm | |
The 50 amp adapter is for when the 30 amp receptacle is damaged or not working.
osage
Senior Member Joined: 13 Mar 2016 Online Status: Offline Posts: 146 |
Posted: 15 Nov 2016 at 7:49pm | |
hammer, small ax for splitting fire wood, small rug to under by steps to wipe feet on
Bama Pod
Groupie Joined: 04 Oct 2016 Location: Huntsville AL Online Status: Offline Posts: 89 |
Posted: 15 Nov 2016 at 6:29pm | |
Consider a 90 degree water hose adapter to connect fresh water hose to pod. Prevents the hose just sticking straight out being a trip hazard. We also purchased a small electric space heater for about 20 dollars. Does not get hot enough to be a fire hazard but keeps the pod fairly warm in moderate temps without using LP gas. 50 to 30 adapter? Not considered that but I figure if I find I need one then I am probably at the wrong campground ($$$).
Bama Pod
Huntsville, AL 2017 Ford F250 2017 Airstream 26U |
