Forum Home Forum Home > General Camping > Cook'n With Gas
  New Posts New Posts RSS Feed: Dutch Oven - Cooking Meat
Topic ClosedDutch Oven - Cooking Meat
rpodcamper.com View Drop Down
Direct Link To This Post Topic: Dutch Oven - Cooking Meat
    Posted: 30 Nov 2009 at 4:29pm
I like to use the best cuts of meat, such as a sirloin roast, because there is no waste and, in case there is any left over, it can be used later in many ways. One half package of dry onion soup mix rubbed on the meat before it is cooked will be all the seasoning that is needed. For a big roast -10 lbs or so- use a whole package. Add a cup of water to your Dutch oven and begin to cook your roast with 8 charcoals on the bottom and 12 on the top. Be sure and not let the oven cook dry.  Add a little water as needed .This is hotter than you would cook biscuits but it works. After about an hour, you will need to add a few new charcoals and now would be a good time to add a couple stalks of celery, two big onions and fill the rest of the oven with carrots and potatoes in what ever proportions you like. If you get the oven too full put a piece of foil over the top .Remember, if you cook the potatoes too long they will be mushy.  Continue to cook about one more hour or until the potatoes are done. You will have gained lots of juice by now and that can be thickened with a little flour or corn starch to make gravy.
     If you are in a place where you can do it, the very best way to cook meat  is to bury it in the ground .  To do this, you prepare your meat and vegetables the same way and dig a hole 2 feet deep and 2 feet across.
  Fill the hole with wood cut into small pieces and add the same amount of wood above ground and then burn the wood until it is reduced to red hot coals.  Separate the coals and after putting a piece of foil over the oven to help keep the dirt off, place the oven down in the coals making sure to get some on all sides, underneath, and lots on top. Cover the oven with the handle straight up and add enough moist dirt to completely cover the fire. If you can see any smoke, add more dirt. It will take about 6 hours for this to cook.  The good thing about cooking this way is you can dig this up in 6 or 8 hours and it will be done to satisfy your hungry party, without being over cooked.
     A turkey also works well to either cook with charcoal or bury in the ground .I just season the turkey with a little season-all type salt and cook with 12 coals on top and 8 underneath.  A 12 pound bird cooks in about 2 hours. Buried in the ground, it really doesn't matter what it weighs, a turkey will be done in 4 or 5 hours.
