Electricity pull |
Neserk
Groupie Joined: 20 Aug 2016 Online Status: Offline Posts: 67 |
Topic: Electricity pull Posted: 15 Jan 2017 at 10:48am |
This is a total Newbie question as I've never camped in a campground in anything but a tent.
I know one of the things that can happen when on a vacation is rain that pretty much keeps you inside. I'm wondering if it is feasible to use a sewing machine or similar appliance when using campground electricity. In my imagination, if I were on a longer trip and stuck inside, it is something I would want to do. Anyone thoughts or guesses? -- Denise |
Bugout
Senior Member Joined: 01 Jan 2017 Location: S caroline Online Status: Offline Posts: 117 |
Posted: 15 Jan 2017 at 10:59am |
You can use your sewing machine have fun
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Podster
Posted: 15 Jan 2017 at 11:00am |
Sure, I don't see any reason why you could not use a sewing machine. I'd probably keep it inside the POD where it is better insulated and grounded.
Cliff & Raelynn
Neserk
Posted: 15 Jan 2017 at 11:20am |
Definitely would keep inside, even in nice weather. :)
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6298 |
Posted: 15 Jan 2017 at 2:34pm |
My wife insisted that ouR escaPOD have a place to store a sewing machine as well as a bathroom when I told her I wanted to get one. We have a compact sewing machine that fits nicely in a little cubbyhole I made next to the wardrobe in the 179. It is definitely doable.
Guests
Guest Group |
Posted: 15 Jan 2017 at 4:55pm |
You will probably be just fine. It is possible to exceed the 30 amp limit - if one was to have on the A/C, water heater - on electric, and microwave at the same time (along with some other smaller loads - like the battery charger/converter). In theory, the circuit breaker on the Pod or campground pedestal would trip. Personally, I try to have on no more than two of the bigger loads (above) at a given time (just one is better). Again, when added with some smaller loads (television, crock pot, whatever), the demand is getting "up there". It would be helpful to know how much power the sewing machine requires. That information is usually placed on the back or bottom of devices and displays the voltage, along with the amps and/or watts. In addition to the total amps available (30), the individual circuit will likely be limited to 15 amps. I doubt the sewing machine (alone) would need this much. However, if there are other things in use on that same circuit (crock pot, coffee maker, etc.), it may trip on overload. |
Posted: 15 Jan 2017 at 5:59pm |
The Janome sewing machine we have for travel draws .6A, so that means it 72 Watts. This is a simple machine. My wife's much larger Pfaff sewing machine draws .9A, or 108 Watts. I really don't think it would cause a problem to take along a sewing machine.
