  New Posts New Posts RSS Feed: Dual LP Tank Mod
Topic ClosedDual LP Tank Mod
famepot View Drop Down
Direct Link To This Post Topic: Dual LP Tank Mod
    Posted: 27 Jan 2017 at 5:52pm
I know others have posted their dual tank mod, but I though I would post my spin.
Here's the single tank mounting bracket.
I removed the bracket and drilled 4 new holes
I filled the old holes with liquid metal
and installed the new dual tank rack
Mounted the tanks (the one on the right is temporary till I get a new one)
I mounted the regulator on a new bracket
and added a new dual tank cover.
Total cost about $60, not including the tank.  Current plan is to manually switch tanks.
CharlieM View Drop Down
Direct Link To This Post Posted: 27 Jan 2017 at 6:53pm
Nice job but you're missing one of the biggest advantages of dual tanks. An auto-switch regulator ensures you'll use all the propane in a tank before refilling and that you won't run one dry in the middle of a cold night.  Murphy's Law says it will happen at 2AM on the coldest rainy night of the trip Approve
Direct Link To This Post Posted: 27 Jan 2017 at 7:25pm
quoted for truth.
Wink
M&M POD View Drop Down
Direct Link To This Post Posted: 27 Jan 2017 at 9:56pm
Nice job. I've got to get this done. My 180 2017.5 is in storage and I need to find out if my holder is welded on or bolted. Bolts would make my life much easier. Sounds like the auto switch reg is the way to go.
Morris & Michelle
2008 FJ CRUISER
2017.5 HRE 180
Direct Link To This Post Posted: 27 Jan 2017 at 11:41pm
Can you tell when it switches over?  Would hate to have them both run dry.
Podster View Drop Down
Direct Link To This Post Posted: 28 Jan 2017 at 6:47am
Looks good. The only thing that I would note is that it appears that you used the stock POD LP regulator that was previously mounted horizontally. In fact, LP regulators are specifically designed to be mounted one way or the other. The vents on the regulator should point down on a horizontal regulator to allow gravity to help shed moisture. Of course, that is not to say the regulator won't work (allow flow) in the vertical position, but mounting it this way may lead to pre-mature failure. I imagine having the assembly inside the cover, as you do, may delay any related deterioration.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 28 Jan 2017 at 7:53am
A red flag appears in a little window indicating one tank is empty and the regulator has switched over to the second tank.
Direct Link To This Post Posted: 28 Jan 2017 at 8:35am
In the 6 years we have owned or 177 we average about 1.5 tanks of propane usage/year.  A couple of times we did burn through 2 tanks because of camping in some really cold weather conditions while in the Rockies.  Would be difficult to end up with 2 empty tanks.  We have 2 tanks on our pod, wouldn't have it any other way.  I suppose if we camped where electricity were available we could use a cube heater but since we like the National Parks propane is our only alternative.
voisj View Drop Down
Direct Link To This Post Posted: 28 Jan 2017 at 1:05pm
+1 on Jato's post,  1 get 10 nights out of my 1st tank, I have a gauge on it and only change over to the second when the gauge says it's almost empty or it feels really lite. I'ts so nice to have the second tank. Because I hate wandering around looking for propane when i need it bad.
On the regulator being upside down or horizontal. I've been using mine like his picture for 4 months. Is this really an issue that I should take care of?
Rgds John
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 28 Jan 2017 at 4:31pm
Rgds John
Worst case scenario is a untimely and premature failure which can happen at any time. A regulator is not very expensive and is easy to replace. So, I wouldn't lose any sleep over it, however, by specification...it should be horizontal with the ventilation pointing down.
Cliff & Raelynn
Ranger 4.0/178
