  New Posts New Posts RSS Feed: Fire Starters - Pine Cones
Topic ClosedFire Starters - Pine Cones
rpodcamper.com View Drop Down
Direct Link To This Post Topic: Fire Starters - Pine Cones
    Posted: 08 Dec 2009 at 2:08pm
Pine cone fire starters can be made as scented or non-scented and may or may not be colored depending on the wax used. You can use candle wax from the craft store, old candle stubs or paraffin blocks from the canning department of your local grocery. For color use candle coloring from the craft store. The scent MUST be essential oils, the type used in potpourri or candle making available at your local craft store or candle supply store. As an added note color and scents are not required for the pine cone to become an effective fire starter.
Wax must be melted in a double boiler. This can be achieved by using a metal can large enough for your largest pine cone to set into with at least two inches head room above the pine cone. Place a mark on the can at the top of your largest pine cone (a coffee can usually works well).
Place the can in a pan of water on the stove. Add broken pieces of wax or candle stubs to the can and allow to melt on medium to low heat until the liquid wax reaches your mark.
Tie a string around a few of the scales. Holding the string dip the pine cone slowly into the liquid wax. Remove and allow to drip over the can until it stops. Place on wax paper and allow to completely harden.
Pine cones can be arranged in a basket or other container and if used as a gift you might add a fancy box of fireplace matches. To use as a fire starter place the pine cone on top of the kindling and light the edge of one of the scales.
CAUTION: Because of the properties in the essential oil, potpourri and scented light rings should not be placed on finished wood furniture without glass protector as the essential oil will damage the finish.
For colored flames you can soak the pine cones in water to which one of the chemicals listed has been added. After the cones have soaked up all the liquid spread them out to dry. When dry you can add the cone to the fire and watch the colored flames dance.
It is best to use only one color per cone or break the cones apart before soaking and then when dry, mix the different chemical soaked scales together when adding to the flames to provide an array of colors.
Mix as much of the powdered chemical into water as will dissolve. The exception is sodium chloride (table salt) which is mixed one half ounce salt to one pint of water to produce yellow flames.
Strontium chloride produces red flames, magnesium sulphate (Epson Salts) gives white flames and calcium chloride for blue flames. Mix the dried pine scales and have a patriotic fire. Other chemicals give you different colors to enjoy.
Copper sulphate (blue vitrol) has a green flame while baronsalts (borax) has a yellowish-green flame and potassium sulphate mixed 3 to 1 with potassium nitrate will show off a violet flame.
ToddsPod View Drop Down
Direct Link To This Post Posted: 13 May 2011 at 5:07am
This was a cool post I thought I'd resurrect and add two cents.
Another good tinder type I picked up at a Boy Scout training outing may be one you have at home or with you camping. Fritos chips act like a slow-burning wick - I'm sure it has something to do with the percentage of fat contained therein. Try it out, once you get them lit they'll burn for a good while, more than paper or cardboard, just enough to get the kindling lit. I haven't tried any other brands of chips, but I'm sure they all have plenty of fuel. You'll have your fire going in no time, that is, if you can manage to not eat them all first.
'07 Dodge RAM 1500 ST Longbed QuadCab 4.7L V8 --- '10 Forest River R-Pod 172
Caverkim View Drop Down
Direct Link To This Post Posted: 13 May 2011 at 2:29pm
Someone I know took a cardboard egg carton, put in a small amount of dryer lint rolled up into a ball into each section, then melted a small bit of candle wax on top of each to hold it in place.  Then they cut out each "egg".  Such a cute idea!
caver*pod 175/Louisville KY
Direct Link To This Post Posted: 13 May 2011 at 8:23pm
I had heard about the trick with Fritos.  I kind of makes me wonder if I should be dumping that much grease in my belly by eating them. Ying Yang
Doing the Scouting thing is cool.  Back in the day, one of the State parks I frequent had a gentleman who used to drive around the campground several times per evening, selling bundles of wood, soda pop, etc.  One of the things he sold was firestarters.  His scout troop made them from a wax/sawdust mixture poured into muffin containers/papers.  Those things worked great and were just the right size to start most fires.
Snowbound View Drop Down
Direct Link To This Post Posted: 16 May 2011 at 3:33pm
Safety tip for melting wax would be to put your wax-melting container into an electric frying pan with  a thermostat. This is a fun craft with older children as long as they are well supervised and is a good way to use up all those candle stubs that accumulate around the house.
B
Tom and Bette
in our 177 "The Gastropod"
DocTom View Drop Down
Direct Link To This Post Posted: 17 May 2011 at 8:37am
I have always used dryer lint or cotton and a little petroleum jelly to get the kindling started. I carry it in an old pill bottle in my pack "just in case".
