  New Posts New Posts RSS Feed: Campfires - Pyramid/Platform Fire
Topic ClosedCampfires - Pyramid/Platform Fire
rpodcamper.com View Drop Down
Direct Link To This Post Topic: Campfires - Pyramid/Platform Fire
    Posted: 09 Dec 2009 at 10:37pm
This fire consists of a foundation framework of large logs laid side by side to form a solid base. A slightly shorter log is laid perpendicular and on top of this first layer. Each subsequent layer is slightly shorter as the platform or pyramid rises. This solid mass of right angle firewood takes a little effort to light but it's well worth it for the huge amount of coals it produces, especially when the fire is lit on the top most layer and burns down through the layers.
A lighter version of the Pyramid fire is the platform. It's similar in shape to the pyramid fire except the logs are layered only along the outside edge (like walls on a log cabin) with each level of logs slightly shorter than the ones beneath. This creates a hollow wood platform into which smaller kindling can be placed and ignited. It can provide quick warmth and be the start of any number of larger blazes.
