  New Posts New Posts RSS Feed: 171 - Mod - Curtains
Topic Closed171 - Mod - Curtains
rpodcamper.com View Drop Down
Direct Link To This Post Topic: 171 - Mod - Curtains
    Posted: 14 Dec 2009 at 4:01pm
The spring rods are pressed up against the valance sides.  When I was taking out the mini blinds up in the front I actually removed the valance (help on by 2 crews on each side and them removed the blind and hanger.  In the back over the bed I started to look at the blinds and figured out that i could unclip the blinds and pull them out without removing the valance.  I kept the blind hanger up there.  I think if i was doing it again I would be removing the valance and doing it the correct way.
Pie_Pod View Drop Down
Direct Link To This Post Posted: 14 Dec 2009 at 7:56am
This is something that I am going to have to talk Ted into.
I am not sure where I found the link.  I know it was on a RV forum but not sure who should get the credit...but, I want to make curtains out of the mini-blinds like in this link:
I removed the bed cover from the mattress.  (We have the Earth fabric)..I have quilts and things that we will be using instead.  So, I was thinking about using the fabric from bed for the curtains.  If I make these curtains, I want a fabric that completely blocks the light when the curtains are all the way down.
I probably will have to practice this conversion so I don't screw it up.  Luckily, I have some blinds here in my bathroom that I have always wanted to get rid of so I think I will experiment on those.
~Cindy_CP
(Pod_Patrol's girl)
177
Tusten Traveler View Drop Down
Direct Link To This Post Posted: 14 Dec 2009 at 5:30am
This is something we want to do too....thanks! Did you just pull out the whole blind mechanism? Did it come out easily? What are the spring rods attached to- the valance sides?
Any more info would be helpful and appreciated.
John and Linda
One 14 lb Cockapoo
2010 RPod 174
Direct Link To This Post Posted: 14 Dec 2009 at 2:40am
OK the blinds that came with the camper just were not our style.  After going out a few times we decided to pull them out and make curtains.  Thankful my wife can sew so that was not a problem.  We installed spring rods up in the valances to hold the curtains.  Below are before and after Pictures:
Drivers Front - After
Drivers Front Before
Passenger Side Front - After
Passenger Side Front Before
Drivers Side Rear After
Drivers Side Rear Before
Passenger Side Rear After
Passenger Sire Rear Before
