Golf Cart Batteries |
Post Reply | Page 123> |
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Topic: Golf Cart Batteries Posted: 21 Apr 2017 at 4:58pm |
There is no doubt that GC batteries are better than the typical group 24 or group 27 batteries usually found on the pod. The usual GC battery is the Trojan 105 or equivalent. This is good, but there is a better choice. Two Trojan 105s provide 225 amp hours of storage. Consider the Trojan 145s that provide 265 amp hours of storage in the same footprint. The 145 is just a bit taller than the 105. The additional 40 amp hours of storage are worth the additional expense. I wish I had known this before buying the 105s
ToolmanJohn
Posted: 21 Apr 2017 at 6:01pm |
Are you boondocking? Do you have a solar panel?
I ask because my plan was to get two T-105's , previously I had two 12 volt Interstate batteries. No problems for a weekend, but I was interested in going a full week, and not use a generator at all if possible (relying on solar charging). I don't think I would need to use the furnace, I would use a portable ceramic propane heater (MrBuddy Heater) instead (uses no electricity) and crack a couple windows and the vent. I've done it before and it works great.
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4517 |
Posted: 21 Apr 2017 at 6:27pm |
We really like our buddy heater, we use in the camper and the fishing shanty. Works great!
Tars Tarkas
Posted: 21 Apr 2017 at 7:41pm |
The cheap price on Amazon for the T145 is $309 -- $189 + $120 shipping. A Duracell Ultra 255 ah is $196 with a 10% discount (about $176 total per battery) if picked up in store at Batteries + Bulbs.
There may be better prices for the T145, I haven't looked very hard, but 2 T145 come to $618 vs $352 for two Duracells. You could almost get 2 Duracells and a 100w Renolgy solar suitcase for the price of two Trojans. I don't know much about batteries, so which is the better deal? TT |
FJ Cruiser |
ToolmanJohn
Posted: 21 Apr 2017 at 9:06pm |
Two T-105's is a LOT of capacity if you don't use the furnace. And much cheaper too.
Have to watch out for the additional weight as well, one regular 12 volt marine/RV battery is about 48 pounds ( 96 pounds for two) . Use two T-105 is 62 pounds each (124 pounds) .A T-145 is 72 pounds each (144 pounds). It adds up fast. And it goes to the hitch tongue weight. Watch your hitch safe tow limits!!
Posted: 21 Apr 2017 at 9:21pm |
We are beginning year #7 on our 2 group size 24 12v deep cycle batteries. During a boondocking campout we expect 3 days minimum from each battery and that is when we camp when the furnace gets used quite a bit (night temps 40's and 50's). When these go bad we will most likely go to 2 6v or 2 12v golf cart batteries. Looking at amp hours for each, price, and of course total weight. Will report back when results come in.
fwunder
Posted: 21 Apr 2017 at 9:31pm |
I went with dual Duracell's (Deka) back in 2014. Couldn't be happier...so far.
As far as heat goes, I have both the Buddy and just recently got Lil Buddy. Lil buddy (3800 BTU) is a better fit inside pod. Buddy (4000-9000 BTU) will blast you out. Both are capable of hooking up to larger tanks than the one pounders. I do use and refill the one pounders for convenience, but I like the larger tank option for longer run time. fred
Posted: 21 Apr 2017 at 9:45pm |
My Duracell batteries have held up well since we bought them in December, 2015. On our last trip, after our propane hose went bad and left us without heat, I picked up a Lil Buddy. It went back for the simple reason that it is top-heavy when used with the one-pound bottles. Back when the base of the bottles was made of metal, it would probably have wirked. Now that the new bottles come with a plastic ring, I could not get it to reliably sit upright. It kept falling over. That was unacceptable and indicates a design flaw if it will not stay upright.
I now have the Mr. Buddy Portable (4000-9000) unit. I agree that it is a bit much for the 'Pod, but it will at least stay upright and not fall over. The thing is that if Mr. Buddy would simply make the base bigger and the socket for the tank deeper, it would probably fix the issues I was having with it. I was not disappointed with the performance and would have kept it if not for it falling over almost every time I tried to use it. |
fwunder
Posted: 22 Apr 2017 at 12:59pm |
You're right Stephen. The Lil Buddy does seem a little top heavy. My Coleman Burner feels the same with a big pot on it.. One solution is a wider base like this: https://www.amazon.com/Stansport-194-B-Propane-Cylinder-Base/dp/B001DC7FPM
The one pounders I have don't have the plastic ring, so maybe that helps.
Or, for a few bucks you can make up a tank adapter for stability and much longer (and cheaper) run time. This is a one gallon tank - good for 4+ one pounders. |
john in idaho
Posted: 22 Apr 2017 at 3:06pm |
How much ventilation - fresh air does one need to run the little buddy? I used to use one in our tent trailer but fresh air was not a concern in that rig....
