  New Posts New Posts RSS Feed: r-pod Power Convertor
Topic Closedr-pod Power Convertor
rpodadmin View Drop Down
Direct Link To This Post Topic: r-pod Power Convertor
    Posted: 02 Jun 2009 at 9:23am
Forest River uses the wfco-8955 power convertor from WFCO Electronics in the r-pod. Here is all the information from their web site link on the product.
WF-8955 55 Amp Power Center
WF-8955ANP       The WF-8900 Series has revolutionized RV power centers with its lighter weight, decorative doors and superior features. The WF-8955 model provides 55 amps and a clean, constant 13.6 Vdc nominal output, for reliable operation of electronics and appliances. Automatic three-stage charging extends the life of your battery with output voltage modes of 13.2 Vdc range “float” mode, 13.6 Vdc range “absorption” mode, and a 14.4 Vdc range “bulk” charge mode. The 8900 Series also maintains peace and quiet, as the cooling fan runs only when needed.
FCC Class B compliance for every power center model means that the units are dsigned not to cause interference with televisions, radios or other signals. Electronic current limiting automatically shuts down the power during overload or short-circuit conditions, protecting the life of your power center and electrical system.
The 8900 Series models provide AC and DC distribution with innovative features. They can accommodate a 30-amp main AC circuit breaker and up to five branch circuits. Eleven-branch DC circuits are available with LED lights for each DC circuit to illuminate and identify open circuits.
Specifications:
UL® and cUL®-Listed. FCC Class B
Warranty period: Two Year Limited Product Warranty
Output power: 55 amps DC output
Input: 105-130 VAC, 60 Hz (950 watt)
Output ranges:
    - Nominal (Absorption Mode) 13.6 Vdc (includes charging and load)
    - Boost (Bulk Mode) 14.4 Vdc
    - Trickle (Float Mode) 13.2 Vdc (after 48 hrs.)
Dimensions: 13.875” wide; 11.625” high; 9” deep
Weight: 7 lbs.
Available in brown and black.
Spec Sheet: WF-8900 Series
Brochure: WF-8900 Series
Manual: WF-8900 Series
campin View Drop Down
Direct Link To This Post Posted: 13 Jan 2010 at 7:03pm
Would this unit automatically transfer to AC power when plugged in? In other words will the various 12 volt loads in the trailer then be fed through the converter from the ac supply?
Castlegar, BC
r-pod 171
GMC Envoy
Direct Link To This Post Posted: 13 Jan 2010 at 8:49pm
Yes, its automatic and uninterrupted, when you plug in or unplug.
Podpatrol View Drop Down
Direct Link To This Post Posted: 14 Jan 2010 at 2:37pm
Excellent information admin !!! Thank-you ....
Direct Link To This Post Posted: 14 Jan 2010 at 5:07pm
Good stuff- thanks!
Hope to see you "out there"
