  New Posts New Posts RSS Feed: Need battery advice
Topic ClosedNeed battery advice
tsherv View Drop Down
Direct Link To This Post Topic: Need battery advice
    Posted: 02 Jun 2017 at 9:43am
I have a 2014 rpod 179. This Summer we will be traveling to Yellowstone NP and Grand Tetons for almost 3 weeks. We are planning on running off of battery, and using a generator / inverter to recharge the battery.
The problem I have is that for 3 nights we are going to be staying in the Lamar Valley, and generators are not allowed. During that time I won't have a way to recharge my battery.
Currently I have the original Interstate battery. It needs to be replaced before I go. I've read a lot of posts with a lot of different battery options. My main concern is getting a battery that will cover those 3 nights without a generator. I don't want to spend a lot because 99% of our camping in general we have electricity.
I would imagine that our usage is going to be pretty minimal. We are going to be away from the camper during the day. At night we will use some lights and possibly a bit of furnace (depending on the temps).
Looking for some advice on what type of battery to get!
Thanks.
Direct Link To This Post Posted: 02 Jun 2017 at 10:10am
We did 3 days/nights boondocking on a single group 24several times. Fridge on gas, didn't need to run the heater, we don't have CPAP needs, etc..
Direct Link To This Post Posted: 02 Jun 2017 at 11:02am
Some folks have recharged their camper battery using their tow vehicle an a set of jumper cables
GlueGuy View Drop Down
Direct Link To This Post Posted: 02 Jun 2017 at 11:39am
As furpod mentioned, switch your fridge to propane. That will save a lot. Consider recharging the battery with your TV. Might also be worth considering a 2-battery setup (2 X 6V or 2X 12V).
Direct Link To This Post Posted: 02 Jun 2017 at 2:30pm
My last battery purchase (April 2016) was 2 - group 24 (12vdc) Duracell from "Batteries + Bulbs". They were on sale for about $70ea., if memory serves. That said, I've had good luck with the group 24 Walmart batteries, also.
If I were in your situation.....
I would buy a new 12vdc group 24 and KEEP the old battery, for now. You will likely pay a "core charge" of about $10, by not returning the old battery. When you get home from your trip, THEN return the old battery and get the $10 "core charge" refunded. This will give you a spare/backup battery, if you need it (at no cost).
Good luck & safe travels!
SDTrialer View Drop Down
Direct Link To This Post Posted: 02 Jun 2017 at 6:31pm
Can you charge using your TV?  I can last with the basics for 5 days.  Heat, lights, fridge on propane with one 12v battery.
Direct Link To This Post Posted: 02 Jun 2017 at 7:22pm
We have 2 group size 24  12v deep cycle batteries that we got when we picked up our 177 back in March 2011.  We still expect to get a minimum of 3 days/nights out of each battery when we camp in the spring/fall when night temps hit the upper 30's to upper 40's.  At those temps the furnace goes on a fair amount at night, during the day we turn furnace off as we will normally be hiking.  Fridge is on propane and we changed all our lights inside to L.E.D.'s; probably standard equipment on your pod.  Like SD Trailer above posted, we easily can get 5 days out of a single battery during the warmer days of summer.
