Possible Overfill of FW Tank? |
Post Reply | Page <12 |
Keith-N-Dar
Topic: Possible Overfill of FW Tank? Posted: 24 Aug 2017 at 5:37pm |
I never understood the thread about overfilling the tank and having it fallout of the pod. I never could see how that could happen.
Keith-N-Dar
clickscrazy
Senior Member Joined: 09 Aug 2017 Location: FL Online Status: Offline Posts: 106 |
Posted: 24 Aug 2017 at 5:50pm |
Man you can learn so much from this Forum just by scanning the posts every so often.
2018 R-Pod 171
2014 VW Touareg TDI |
Tars Tarkas
Posted: 24 Aug 2017 at 6:06pm |
Yeah, I guess you're right. I always figured that was more for making sure a vacuum isn't created in the tank. TT |
FJ Cruiser |
Posted: 24 Aug 2017 at 6:26pm |
Keith n Dar - it wasn't about overfilling tank. It was about the weakness of the rail attaching sheet metal screws. I personally bolted mine thru frame rails. One rail on every tank is secured by short sheet metal screws. Mine had pulled and were not secure. There is documented loss of tanks. I took precaution of making sure that didn't happen.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6297 |
Posted: 26 Aug 2017 at 12:19pm |
+1
After reading a post about the loss of a black water tank, I checked ours. I saw screw threads between the rail and the frame, some of which were bent. I took it to the dealer where they were tightened. One was stripped at that point so a new hole and screw were used. After I got it home, I went to my local Lowe's and bought stainless steel bolts, washers, and lock nuts. I replaced one screw in each bracket with a bolt, washer, and nut. My tanks are not going to fall off. The black and gray water drain valve suspension is another point of failure. I had the black water drain drop down when the nut (not a lock nut) dropped off the machine screw holding it up. I wasn't happy about that. It was less expensive for me to repair it than for me to tow it to the dealer to fix, so I ordered a new output pipe and cap since the valve was still good. It got a lock nut this time around and will probably be reinforced before our next trip as I have seen some pictures of the hanger where it rusted through and failed also. |
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Posted: 26 Aug 2017 at 1:29pm |
It's probably worth it for most of us to crawl under our various 'pods and examine the way things are held up (or not). I know from having worked on aircraft that there were stringent rules for how things are fastened. On an R-pod you can pull over to the side of the road. In an aircraft your options are much more limited, and the consequences considerably more dire.
