  New Posts New Posts RSS Feed: Brake Wires
Topic ClosedBrake Wires
Wepod View Drop Down
Direct Link To This Post Topic: Brake Wires
    Posted: 13 Sep 2017 at 10:51am
I just crawled under under my pod and i noticed the passenger side brake wires were pulled out of the connectors.   I couldn't tell what color the wires were because of accumulated dirt and crud.  What colors should the wires be and what wires go to what.  Also do I Need those funny connectors on there or can I just use regular butt spices on them.  Thanks.
Direct Link To This Post Posted: 13 Sep 2017 at 2:24pm
You can use any connector you are comfortable with, and wire color doesn't matter. It's a DC electromagnet. Current in either direction has the exact same effect.
voisj View Drop Down
Direct Link To This Post Posted: 13 Sep 2017 at 10:22pm
+1
The wires on both sides on my brakes came out of the connectors and I can only assume it happened when I hit a huge dip in the road in Escalate Utah,and the pod actually came airborne. The wires are not long enough for this kind of thing.Everything emptied from every cabinet, what a mess! I just hooked them back up with new connectors and all is good now.
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 15 Sep 2017 at 10:30am
Thanks for the reply's,  I think I will change out the other side too.  Then I can wrap them in wire loom to protect the wires.
