  New Posts New Posts RSS Feed: Tank leaking
Topic ClosedTank leaking
Wepod View Drop Down
Direct Link To This Post Topic: Tank leaking
    Posted: 08 Oct 2017 at 9:29pm
Oh thank you all for the replies
Direct Link To This Post Posted: 09 Oct 2017 at 7:36am
Originally posted by Wepod
Well I did disconnect the city water and am using the pump now but the pump has been cycling on a few minutes after Shutting off for about a week now. Is the check valve in the pump or inline after the pump?
The check valve is built into the front of the pump. It's literally a little rubber disc/flap.
If the pump is cycling repeatedly after you have closed the tap, you have a leak somewhere.
The system should, and will, hold pressure for months. I have opened the system on Pods I knew had been sitting for weeks to months, and got sprayed by water under pressure when I forgot to open a valve first, before opening the plumbing lines.
john in idaho View Drop Down
Direct Link To This Post Posted: 09 Oct 2017 at 9:49am
Our POD had been sitting for 3 months and I decided to drain the hot water tank.  Guess we have a pretty tight water system  - the pump hasn't been on in that 3 mo period - and it blew the anode and and my socket wrench about 10 feet and drenched me from the waist down.
Direct Link To This Post Posted: 09 Oct 2017 at 10:20am
LOL.. Most owners only open the system one time without releasing any pressure.. Remember, right there on the WH is a pressure relief valve.. I always pull it first.. now.
Direct Link To This Post Posted: 09 Oct 2017 at 12:09pm
Yep
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 09 Oct 2017 at 2:09pm
I did the same thing the first time I winterized the pod.  And the second time.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 09 Oct 2017 at 6:06pm
Thanks Mark
