itspossible2
Topic: Jensen radio Posted: 30 May 2018 at 4:34pm |
I have a 2015 178 and whether plugged into 120 volts or on battery something weird happens. I'll walk by the unit in the driveway and the radio is on, even though it was turned off. I've been working on her unit outside and all of a sudden the radio turns on again, for no reason. I was thinking of adding a switch to the power line just to stop accidental battery drain, has anyone else had this issue? thanks
Posted: 30 May 2018 at 5:12pm |
Check the ALARM function and make sure it is OFF.
itspossible2
Posted: 31 May 2018 at 9:45am |
thank you, I think it was the alarm.
TheBum
Posted: 31 May 2018 at 10:28am |
Ah, and here I was suspecting it was gremlins. :)
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
lgblau
Posted: 31 May 2018 at 12:49pm |
I had the Jensen in my last motorhome, and it would come on in the middle of the night ( usaually at an rv park).Finally had to disconnect the outside, entertainment center, speakers.
Leonard🌵
2017/179
2017 Ram 1500
Posted: 31 May 2018 at 3:07pm |
Tat was Gremlins. I've had those too.
Leo B
Posted: 31 May 2018 at 3:39pm |
I was thinking of ghosts or your someone messing with you!
itspossible2
Posted: 03 Jun 2018 at 6:55pm |
Problem solved, I spliced a switch into the power wire to the radio and use it to disconnect power rather than using the power button on the unit. This also puts an end to power drain from the battery when the radio is off but drawing power for the clock.
