  New Posts New Posts RSS Feed: Brakes Stock On
Topic ClosedBrakes Stock On
Tom A View Drop Down
Direct Link To This Post Topic: Brakes Stock On
    Posted: 09 Jun 2018 at 3:19pm
I have a new Pod that has been on one short trip so far.  It has been parked for the past six weeks on my inclined driveway.  I got a new TV and hauled the Pod two blocks away to a parking lot so I could measure the the receiver height level.  After I got my measurement and got reattached I noticed it felt kind sluggish to pull and I heard soft brake squeal even when my brakes were not applied.  I suppose it's possible that it was the same when I towed it to the lot, but I wasn't aware of it.  When I got parked at home again my wife said the wheel was smoking-- sure enough the brake drum was hot to the touch.
Now what do I do?
Is it possible that the brakes got rusted and stuck in the past six weeks?
2018 Sequoia--2018 RP 190
Pete Brayton View Drop Down
Direct Link To This Post Posted: 09 Jun 2018 at 3:30pm
Check your emergency breakaway switch. It might have been unplugged.
2021 Rpod 196
2013 Ford 150 V8
mcarter View Drop Down
Direct Link To This Post Posted: 09 Jun 2018 at 3:37pm
One side? The Ebrake switch should engage both sides. Unless there is a wiring issue at hub that only allows one brake engagement. Checking switch is easy. After that look at locked side.
Direct Link To This Post Posted: 09 Jun 2018 at 4:35pm
Well DUHH!
That was it.
Thanks.
Direct Link To This Post Posted: 09 Jun 2018 at 6:14pm
Glad you found that issue, so you had one locked brake? I could be wrong but I don't think the ebrake locks one brake. I need to check.
Direct Link To This Post Posted: 09 Jun 2018 at 7:03pm
I only touched one brake drum, and my wife only saw the one I touched because of where she was standing. I'd guess they were both hot--on.
