Manual operation slide out 189 |
3sunsets
Newbie Joined: 07 May 2018 Location: Berrien Springs Online Status: Offline Posts: 13 |
Topic: Manual operation slide out 189 Posted: 10 Jul 2018 at 4:37pm |
Getting to know our new 189 but so far have found no info on manually sliding our slide in (or out) just in case we have no power. If I know, I’ll probably never need to use it, but if I don’t, it’s bound to happen...thanks for any help
The links I’ve found that mention this issue are inactive and from 14 years ago
GlueGuy
Posted: 10 Jul 2018 at 4:43pm |
Our dealer claimed it was possible to push the slide-out in if the power was turned off. I kind of doubt that, but I'm willing to be convinced.
Posted: 10 Jul 2018 at 10:35pm |
The slide-outs can be manually retracted if needed. There are YouTube videos showing how. In essence, one has to go into the upper slide mechanism, loosen the motor and move it up to disengage it, repeat for the other side. When both are disconnected, push the slide-out in and then use wood to brace it. Then drive it to your dealer's repair shop or other authorized repair center to get it fixed as you likely won't be able to get the motors back in place yourself. We have had our RP179 since December, 2015. We have covered probably over 25,000 miles with it and the slide-out has not had a single problem. It is nice to know what needs to be done if it does fail, but if it is working, don't worry abut it.
crankster78
Senior Member Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Posted: 11 Jul 2018 at 9:03am |
Greetings The company that makes the slideout mechanism has a series of videos on both manually operating and synching the slide out. It will tell you everything about it that the dealer didn't Crankster78
Crankster 78 R-179 2015
3sunsets
Posted: 11 Jul 2018 at 10:48am |
Thanks for the reply...I’ll check for those videos
3sunsets
Posted: 11 Jul 2018 at 10:50am |
Thank you... I’ll look for those videos....happy to hear it hasn’t been an issue with yours...
Posted: 11 Jul 2018 at 2:04pm |
No power is not a common problem. If the batteries are dead, connecting the R-Pod to the tow vehicle will supply power. If tow vehicle is not available, connecting to shore power will allow the converter to supply power. If all that fails which is unlikely, then you still might be able to use a generator's 12V power connection to supply 12V power. In any case, lack of power is not something you should lose sleep over.
3sunsets
Posted: 11 Jul 2018 at 4:12pm |
thank thanks thanks...
