  New Posts New Posts RSS Feed: Water heater
Topic ClosedWater heater
mjlrpod View Drop Down
Direct Link To This Post Topic: Water heater
    Posted: 07 Oct 2020 at 11:09am
When you turn on the W/H switch inside, The DSI Fault light should light. Then you should hear a series of clicks (not very loud) That is the igniter trying to light the gas. If it lights, the DSI Fault will shut off. If it doesn't light, It will make 3 attempts to light. If all 3 fail, it will no longer attempt to light. If you go outside and open the panel, and have someone turn it on, see if you smell propane. Don't get your face to close incase it lights and "swooooosh" no eyebrows. If you smell gas, and theres no flame, it's probably the igniter needs changing. I've heard some say they lit it with a match, but I never have.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
SC for Huskers View Drop Down
Direct Link To This Post Posted: 07 Oct 2020 at 12:25pm
I had an additional problem you may have.  When I turned the inside switch on, I heard the clicking (trying to light) then the swoosh meaning it lit.  Then after 15-30 seconds it shut down.  Found the control board, that’s mounted on the h/w tank, was defective.  I had to unplug it, take it to the local dealer who tested it.  Twas only 6 months old.
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Kingbro View Drop Down
Direct Link To This Post Posted: 07 Oct 2020 at 12:29pm
nothing tripped
Kingbro
Direct Link To This Post Posted: 07 Oct 2020 at 12:42pm
Jay, Thank you for your suggestions.  The rocker switch is illuminated but the DSI light which is supposed to light to show it is trying to light the heater.  I'll try to find the wiring and check with a multimeter.  I once had an issue with a fireplace gas insert and the issue ended up being a spider in the orifices'. I'm not comfortable taking a gas appliance apart and putting it back together (especially knowing my head will be resting about a foot aboveLOL)  Might have to go to a repair person.
Kingbro
JR View Drop Down
Direct Link To This Post Posted: 07 Oct 2020 at 3:35pm
Kingbro, after checking the water heater manual the 12 V.D.C. T-Stat Hi-limit might have tripped and be causing what you are experiencing.  This is a High limit water temperature cut off and if that sensor is tripped you can manually reset it behind the outside door in the upper left corner just to the left of the pressure relief valve you will see two black reset buttons the left one is for the 110 system and the right one is for the gas system.  If the water temperature got above 180* it should trip both systems and to reset these sensors the water temperature in the tank has to be below 110* then you can push the buttons in to reset both of them or either one.  You might want to try resetting them first.
Jay
179/2019
Direct Link To This Post Posted: 08 Oct 2020 at 5:18pm
When i turned on the toggle I heard clicking at the water heater like it was trying to start ran out and put a lighter to it and got a whoosh and it stayed lit for 15 seconds and then went out.  Tried that a couple of times with same results.  I've got a call in to a local service guy.  I'll keep you posted.
Kirt
Kingbro
Badweissenbier View Drop Down
Direct Link To This Post Posted: 09 Oct 2020 at 10:06am
I found on my 190 that all the wires going to the water heater control box from the switch panel had bad connections.
Whomever crimped the wires from the switch Panel to the igniter control box leads did an absolutely crappy job(to the point of being dangerous). One fell apart on its own and all the rest were very loose. I found them by luck when winterizing last year.
needless to say I bought new connectors and did the job right, then I pulled the switch panel and checked EVERYTHING.
Direct Link To This Post Posted: 26 Oct 2020 at 3:04pm
Turns out it was the circuit board that is attached to the water tank.  Thank you for all your suggestions.
Kingbro
