  New Posts New Posts RSS Feed: What tires will fit in rPod wheel wells?
Topic ClosedWhat tires will fit in rPod wheel wells?
TearlessTom View Drop Down
Direct Link To This Post Topic: What tires will fit in rPod wheel wells?
    Posted: 11 Feb 2019 at 10:22pm
Originally posted by GlueGuy
Originally posted by offgrid
BTW, I may be making an incorrect statement when I say my trailer doesn't have the axle riser kit. I bought it used this spring so that was just an assumption on my part based on it not being a west coast trailer.  I just pulled a wheel to repack bearings and there is a 3-1/2 inch spacer bolted between the axle and the frame. Is that the riser kit?
Sounds like it could be. You might measure the distance between the frame and the ground to check the height. Our HRE does not use risers, but instead they "clocked" the torsion axle to increase the height.
Please explain the process and term of "clocked the torsion axle" ?
Thanks
Tearless Tom
2017 R-Pod 180
2014 Ford F-150 XLT 2WD 5.0
Direct Link To This Post Posted: 12 Feb 2019 at 4:46am
GlueGuy is referring to the starting angle of the spindle arm as it exits the ends of the torsion axle. If it exits at a more downward angle the ride height of the trailer is raised and vice versa. The starting angle is set at the factory and the axle manufacturers have several angles available.
john in idaho View Drop Down
Direct Link To This Post Posted: 12 Feb 2019 at 10:42am
I put E tires on mine.  At 80lbs air pressure, there is no noticeable sidewall squishing in the outside mirror. Can tell no difference in ride quality.  At least it makes me feel better.
Direct Link To This Post Posted: 12 Feb 2019 at 11:01am
Ok thank,so your saying it is not something I can change. My only option is to get the risers if I wanted a little more height.   I was surprised when  I was almost scraping just backing into my driveway.   I'm looking into getting some 15 inch tires as well.
I did order the quick release for the rear stabilizers and will put them on if it ever stops raining.
they are heavy and well made.  Kinda price for what it is though.
Tearless Tom
2017 R-Pod 180
Direct Link To This Post Posted: 12 Feb 2019 at 11:32am
That's correct, you can't change the starting angle.
I went to 15 inch tires and wheels, got these. They fit fine in the wheel wells with the risers. So far I'm pretty happy with them but I don't have many miles on them yet. 2500lb rating on both the tires and wheels. You need the 5 x 4-1/2 inch bolt pattern.
mcarter View Drop Down
Direct Link To This Post Posted: 13 Feb 2019 at 11:10am
Saw that etrailer.com is now selling Goodyer Endurance tires. Got an ad today.
Wepod View Drop Down
Direct Link To This Post Posted: 13 Feb 2019 at 4:07pm
Offgrid I got the same tires and trims for my 179. I have been very happy with them after about 10,000mi.
Direct Link To This Post Posted: 14 Feb 2019 at 6:35am
Good to know Wepod. A big selling point to me besides the load capacity was the pre-mounting. In my area that saved $100.
