Lazy Goose
Calendar Event: Panel under the fridge in a r pod 179 Posted: 07 Feb 2019 at 1:40pm |
Hi all was wondering what to do about the panel that wiggle under the fridge. It rocks back and forth, the wire showe awful design. Any ideas?
Posted: 07 Feb 2019 at 2:50pm |
Yep, it’s a weak spot for sure. So far I’ve just moved my panel over slightly and replaced what looked like drywall screws with self tapping sheet metal screws. When I run out of room for that I plan to use bolts and nylocks. Others have tried reworking the wiring, I’ll leave that to them for comment.
Lazy Goose
Posted: 07 Feb 2019 at 3:56pm |
Thank you. I just think that if the wires were put up because it causes the panel to push out.
JR
Posted: 07 Feb 2019 at 4:06pm |
I have a 2019 179 that I picked up the end of July last year (which still makes me a newbie) and trying to find out what is where I have had the panel under the frig off a couple of times and mine is mounted into some square steel stock behind the panel and it is secured with 4 beefy self tapping screws. Which as I remember they are fairly long screws thus when reinstalling the panel you have to be careful to catch the square stock. I haven't had any problem with mine panel falling off or pushing out either. Hope this helps. Jay
Jay
179/2019
GlueGuy
Online Status: Online
Posted: 07 Feb 2019 at 9:12pm |
FWIW, we have had the panel off a couple of times, and it seems pretty secure. Further, the wire loom has an S curve in it, and it does not get hung up when the slide out goes in or out.
Is this maybe just an issue with east coast RP-179s?
john in idaho
Posted: 08 Feb 2019 at 10:45am |
2015 179 here. My panel was held on by 8 staples, of which only two were into something solid. A roll of paper towels got behind it underway, and it popped off when we ran the slide out.
Lazy Goose
Posted: 08 Feb 2019 at 11:28am |
It is a very bad design. Was thinking about replacing it with a better piece of wood on a hinge then place elastic across to hold shoes.
TheBum
Posted: 08 Feb 2019 at 11:30am |
Adding a hinge is on our to-do list, but the hinge needs to be able to swing both ways.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Lazy Goose
Posted: 08 Feb 2019 at 11:48am |
True Alen, also thinking about using a long spring to hold up the big wire.
R&J
Posted: 14 Feb 2019 at 1:26am |
Yes we have done the same in the OzPod.
Rhona & John
POD: 2015 179 'OzPod'
Tow: 2014 Holden Colorado
