  New Posts New Posts RSS Feed: Actual Weights as measured
Topic ClosedActual Weights as measured
Direct Link To This Post Topic: Actual Weights as measured
    Posted: 08 Oct 2019 at 6:54pm
Originally posted by Olddawgsrule
Here's where I now sit dis-mystifying the magic. And only 'my understanding' of the magic!
Offgrid explained the torque I see as actually being moments of the action introduced by the WDH. I get what he's saying now mostly from watching the video I offered. The magic is being explained.
The down force on the ball from the trailer is not removed. The force (moment/torque) is being displaced by the WDH through it's action. Thus sending X forward and X backwards. Then again that amount being determined by the axle length of the TV (I think I've learned). That again becomes a question of why if the weight of the ball is not removed, then where do we get the addition weight on both the TT & TV?
The weight on the hitch itself is not removed from the hitch but it is removed from the TV rear axle. Think of it this way:  in a statics problem (where things aren't actually moving around) all the forces have to balance to zero and all the moments (separately) have to as well. If the forces don't balance then things would rise up or sink down and if the moments don't balance things would rotate.
The weight of an object is of course a force pressing downward and is countered by an equal and opposite upward force from the ground.   So, since tensioning the wdh applies moments which are balanced by increasing forces pressing up from the ground at the front axle and the trailer axle, then there has to be an equal reduction in the force pressing up from the ground somewhere else, because the total force pressing up by the ground has to equal the total weight of the rig, which isn't changing. That somewhere else is the TV rear axle.  So the downward force on the hitch itself doesn't change but the downward force on the rear axle does. The front axle load gets higher and the rear axle load gets lower, both of which are good things for your TV.
There are some downsides though.  There is now a new downward point force on the trailer frame from the tensioning chain/bracket, and there is more load on the already heavily loaded trailer axle. And there is also a moment placed on the TV receiver and frame which wasn't there before. So the tow vehicle and receiver have to be rated for a wdh and the load of the trailer and hitch have to be within those specs. The trailer frame and axle should be rated for the additional load too, which is where axle and frame reinforcement come in.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 09 Oct 2019 at 1:42pm
Originally posted by offgrid
Re the strength of a weld, a good welder can make a weldment just as strong as the steel he or she is welding (emphasis on good welder using the proper technique for that weld). If we're talking about adding a doubler tube under the existing tube that is a pretty benign thing to weld because the mating surfaces of the two parts will be at or near the neutral axis of the weldment. The neutral axis is the cross section where there will be no stress (in other words, the location where the parts transition from being in compression to tension when placed under load).
With a bit more research, I find that properly done, the weld can actually be stronger than the parent metal. That does surprise me! I always thought there would be some give in the process.
Live and learn! Thank you for the input.
Now, for fun of this conversation and how our tongue frame is done. 2x4x.1 steel is everywhere. Being the tongue is welded to the front cross member vs. the tongue being the through member. My mind goes towards the tongue going through would be stronger due to the 'hollow' of the 2x4x.10 cross member. I would think the moments (see, I  am learning.. I think..) happening in the tongue frame are greater than those of the cross member.
I do think that stacking (not sure of correct term being it would be under) in our existing position would do the deed to enforce the tongue frame. I would also go as far of thinking even a 2x2x.10 steel tube (matching the parent steel) would help in a major way.
I see far too many folks adding storage boxes, second propane tanks and some many other carrying racks without considering what really happening. Then of course we add a WHD into the mix.
All said and not attempting to take away from the original threads purpose, I do believe all this is relevant. FR basically is saying their tongue design is meant for (in my case) 385#. 10% of the max weight of the trailer. If over, how do we compensate? I load behind the axle to reduce, yet best I figure, I'm still 15# over. Then comes the action (moments, still tryin' here) of the WDH.
I'm not saying we own a piece of crap.. We have a pretty decent unit for the dollar and a couple hundred dollars to get it to where it can be is well worth the effort and expense.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 09 Oct 2019 at 6:04pm
I'll take a look at the numbers when I get home but I think a 2x2 tube is a good idea. It will add strength without compromising clearance much assuming there is a 4 inch riser at the axle.  I'd probably go a little thicker than 0.1 though, and extend it from forward of the wdh attachment to aft of the front of the trailer box a couple of feet. I do agree that adding a bit of reinforcement to the rpod frame and axle on the heavier units would go a long way to make them more robust.
Direct Link To This Post Posted: 10 Oct 2019 at 7:49am
If I may ask you, could you run numbers on 1x2x3/16" (7 gauge steel)? That's what my frame repair is and would match up for the tongue support. Yes, it's on the flat..
Byways no Highways
2017 Tacoma
Truck Camper Build
Jeepinator View Drop Down
Direct Link To This Post Posted: 10 Oct 2019 at 3:24pm
Such a great discussion.  I'm living in the "moment".
Based on documented failures, isn't the weld from tongue to frame one of the most significant points for potential failure?  That being the case, I was considering adding reinforcement there as you would not have to give up any clearance on the bottom.  I did examine the weld and it looks pretty crappy.  A shimmed piece of angle properly welded would significantly increase the strength in my unqualified opinion.
I was also going to weld the bolt-on receiver as it tends to flex with the WDH.  I just have to confirm I can still remove my Jeep bumper.
2018 Jeep Wrangler Willys
2017 179
Direct Link To This Post Posted: 10 Oct 2019 at 4:04pm
As we all are due to Offgrid and his knowledge on this. I do thank him for being so willing.
The question of how is important to all of us. We don't want to just weld more steel/weight without knowing just what the benefit will be. I just went through an examination of the tongue with my dealer repair pro. I was amazed at the tongue weight empty (I do mean no tank or battery there) and it read 375# (or there abouts). Base weight, nothing added and we come very close to what is suggested by FR. Deflection according was only 1/4" as weight was placed upon.
Throw a propane tank (singular) and my dual batt's, I've added close to 100#'s on that tongue. Given we can back load (behind the axle) to compensate, and we add a WDH. What shall we do to compensate?
That becomes the 'moment' / action we need to deal with.
My Dealer contact had that 'Deer in the headlights' moment when I asked... Pun intended!
As my experience continues, and that of others continue to figure out, we shall work this through.
I do wish this thread continues!
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 11 Oct 2019 at 5:03pm
[/QUOTE]
Will do. I finally got home before the road on the island got shut down due to ocean overwash so I should have time to runs some numbers tomorrow.
My 179's tongue weight is closing in on 550 with full fresh water, dual GC2's, one (not two) full propane tanks, and not much of anything else heavy forward of the trailer axle. Total weight is about 3800 so that's around 14% tongue weight. So yep, as Podwerks says, FR's tongue weight numbers are really not anything like the real world for anyone who does much boon docking with the bigger rpods.
You have to be careful though too about moving too much weight aft. If, like me, you are returning with all that water moved to the 179's gray water tank that reduces tongue weight percent to about 11. Get much lower than that and the trailer can be sway prone, so there is a sweet spot for me around 14% outbound and 11% inbound.
