  New Posts New Posts RSS Feed: Adding Solar Plug to 2011 177
Topic ClosedAdding Solar Plug to 2011 177
Grant177 View Drop Down
Direct Link To This Post Topic: Adding Solar Plug to 2011 177
    Posted: 21 Apr 2020 at 10:51pm
Hey all,
Built myself a solar suitcase (2 x 100w) and going to add a flush mount SAE connector to the outside of the 177 to ease connecting it. I have a single 105Ah, deep cycle, FLA on the 177.  Is there an easy location to connect the solar controller to the leads from the battery inside the trailer?   I'm assuming under the seats, but being new to the R-Pod, have not been able to delve too deeply yet.  I have the solar panels (fused) connected to the solar controller, then the controller output (fused) which I am hoping I can easily connect inside the RV.
Grant
2011 R-Pod 177
Direct Link To This Post Posted: 22 Apr 2020 at 5:45am
Consider connecting the solar charge controller at the battery itself. Then you don't have to make any penetrations into the trailer, and you can mount the SAE connector to the battery box.
Also, the fuse for the controller should go at the battery end of that cable, not the controller end. Fuses are there to protect against damage from short circuits. The source of current that could cause damage if the cable gets shorted is the battery, not the controller or solar modules.  Solar modules are self limited in current output, if you short them out nothing happens.  If you short out the battery you get a meltdown. For the same reason, you don't need a fuse on the solar module side of the controller.
geewizard View Drop Down
Direct Link To This Post Posted: 22 Apr 2020 at 6:32am
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
