  New Posts New Posts RSS Feed: Propane Connection Question
Topic ClosedPropane Connection Question
AUMAN View Drop Down
Direct Link To This Post Topic: Propane Connection Question
    Posted: 19 May 2020 at 11:46pm
 Have a Char Broil X200 Grill2Go with regulator on control knob for 1 lb tanks but want to connect to R pod propane outlet. I think propane from pod is already regulated. Please advise what I need to operate on pod propane connection. Thanks
mwsjr
podwerkz View Drop Down
Direct Link To This Post Posted: 20 May 2020 at 8:22am
One of these might work:
I prefer to use a small refillable bottle and hose, so I can use my tabletop grill at a greater distance from the trailer.
mjlrpod View Drop Down
Direct Link To This Post Posted: 20 May 2020 at 8:24am
As you stated, you have a grill with a regulator, and the pod propane connection is regulated. So a double regulated hook up will not work. Your choice is either remove the regulator from the grill and NEVER attach it to any other supply (it will be unregulated) or don't run it off the pod. Plenty of youtubes on this. I seen one that they put a quick disconnect on the grill regulator, so it's easy on, easy off.  Me, I carry a blackstone (flat top) and a weber Q grill, and I run a tree off a 20 pound between them. I like to save my propane for the h/w, fridge, etc..
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 20 May 2020 at 8:29am
+1. I originally thought I would want to connect to the rpod tank too but in reality the little 1 lb cylinders last quite awhile and provide a lot of flexibility. I do a fair amount of grilling and maybe go through a couple a year, not a big deal.
Pod People View Drop Down
Direct Link To This Post Posted: 20 May 2020 at 8:45am
I would agree that using the 1 pound propane cylinders is the better option. We thought about hooking into the Pod's propane tank, but the hassle and expense wasn't worth it in our case-you may decide otherwise.
It is far more important to save the propane for the Rpod refrigerator, stove and heat  and it's easy to carry a small cylinder for the grill
my 2cents
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 20 May 2020 at 8:57am
Thanks everyone! I'm sold! 1 lb cylinder it is!
Mike
mwsjr
Direct Link To This Post Posted: 20 May 2020 at 10:19am
Here is my setup, one reg. for the pod and one for my quick connect outside.
Direct Link To This Post Posted: 20 May 2020 at 2:21pm
I use the little refillable 11# (~1 gallon) tank...super easy to carry and lasts quite awhile...of course carrying a couple of one pounders for backup.
