  New Posts New Posts RSS Feed: Pre-Tow Checklist
Topic ClosedPre-Tow Checklist
Direct Link To This Post Topic: Pre-Tow Checklist
    Posted: 14 Oct 2020 at 7:17am
There have been a couple of requests for this, so I thought I'd start on one. I'm certain I'm missing some good stuff so feel free to add/comment. I'll try to clean it up and organize it after a few days.
Campsite:
Gear - stowed
Clean up - complete
Slide top - clear of debris
Slide area - clear
Do the following in a "sterile" environment, eg, no side conversations, distractions,  or interruptions. OK to split duties by section.
Trailer interior:
Table - stowed
Cushions - stowed
Counters - cleared
Lights - off
a/c thermostat - off
Furnace thermostat - off
water heater - off
Water pump - off
Bath faucets - off
Shower  - stowed
Bathroom door - closed
Pocket doors:  Open and secured
Sink faucet - off
Sink - drained
a/c water heater element - off
Windows - closed
Bath vent - closed
TV - stowed
Fridge - set to 12V
Fridge contents - stabilized and sealed
Fridge door - latched
Cabinet doors - latched
Slide - in
Hitch connection
Coupler - latched
Jack - retracted and stowed
Jack pad - stowed
Safety chains - connected
Breakaway brake cable - attached
7 way connector - latched
Weight distribution hitch - lubricated and tensioned
Sway control - lubricated and set
Tools - stowed
Trailer exterior
Shore power cable - disconnected and stowed
City water hose - disconnected and stowed
Satellite/cable coax:  Disconnected and stored
Satellite antenna/dish/dome:  Stowed
Propane cylinder - valve closed
Stabilizers - retracted
Stabilizer pads - stowed
Lights - off
Door - closed and locked
Step - retracted
Railing - stowed
Storage door - closed
Water heater door - closed and latched
Outside shower faucets - off
Shower door - closed and locked
Operational
Tow vehicle fluid levels - checked
Tire pressures - checked
Headlights - checked
Brake lights - checked
Turn signals - checked
Running lights - checked
Pets - secure
Engine start, roll forward
Oil pressure - check
Fuel level - check
Brake controller - connected
Trailer brakes - checked (rig stops with trailer brakes only)
Legos - stowed
Storage door - closed and locked
Final walkaround - complete
Family members - seated in TV
Bladders - emptied LOL
Seatbelts - secure
Navigation - ready
Dump station
Gloves - on
Hand sanitizer - ready
Sewer drain area - rinsed
Blackwater
Gate valve - closed
Cover - remove
Hose inlet - connected
Hose outlet - secured
Gate valve - open
Tank - drain
Tank - backwash as needed
Gate valve - closed
Hose - disconnect
Cover - secure
Toilet - add chemical as required
Toilet - precharge water
Gray water
Gate valve - closed
Cover - remove
Gate valve - open
Tank - drain
Tank - rinse as needed
Gate valve - closed
Hose - disconnect
Cover - secure
Hose - rinsed and stowed
Sewer drain - rinsed
Gloves - discard
Hands - sanitized
Sanitizer - stowed
Water pump - off
Faucets - off
Step - retracted
Railing - stowed
Fresh water fill
Fill source - potable
Fill hose - clean
Tank - full
Fill cover - closed
Fill hose - stowed
What did I miss? StarStarStar
john in idaho View Drop Down
Direct Link To This Post Posted: 14 Oct 2020 at 9:53am
Everyone should keep a copy of this handy, for when one of the kids says -" Hey , dad.  Can we borrow the trailer this weekend?  Some of the guys want to go fishing."
Direct Link To This Post Posted: 14 Oct 2020 at 12:21pm
Most impressive OG !  Wow, I guess after camping for the past 40 years; 34 years by tent or pop-ups and the last 10 with our 177 these are done 'automatically' in our heads.  However as I age, I suppose a list similar to what you have posted will become a necessity someday.  It will then get to the point of "now where did I place that list?"  Maybe laminate it on a wall on either the inside or outside?  Hmmm.
poston View Drop Down
Direct Link To This Post Posted: 14 Oct 2020 at 12:30pm
Laminate and strap it upside down on your thigh, like fighter pilots.  Maybe both thighs so the font is large enough to read!
Jim
Virginia City, Nevada
2016 R-pod 180
2015 Nissan Xterra Pro-4X
Pod_Geek View Drop Down
Direct Link To This Post Posted: 14 Oct 2020 at 12:45pm
Originally posted by offgrid
...What did I miss? StarStarStar
Beer:  Finished
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
Direct Link To This Post Posted: 14 Oct 2020 at 1:11pm
Beer:  Finished
Thanks, good suggestions, I don't use any of those items except the beer.Tongue I'll add them.
Since this is like a pilot's pre-fight checklist I'll have to add the beer using the "8 hour bottle to throttle" rule. LOL
I also realized that I put the fridge on 12V but didn't mention turning off the propane.
