  New Posts New Posts RSS Feed: trailer marker light doesn't work
Topic Closedtrailer marker light doesn't work
pedwards2932 View Drop Down
Direct Link To This Post Topic: trailer marker light doesn't work
    Posted: 06 Jan 2021 at 8:00am
Bad ground can do weird things.  The fact that you got some light (low voltage maybe) indicates the bulb is okay so I think you are on right path having it checked.
JR View Drop Down
Direct Link To This Post Posted: 06 Jan 2021 at 9:09am
If I am following you correctly you're just having problems with the left tail light (running light, stop light and turn signal) working correctly.  If that is correct then I think the problem is in the grounding of that tail light fixture (left) only.  The ground from the trailer to the TV should be good because the right tail light is working correctly.  Hope this makes sense to you and helps.
Jay
179/2019
