  New Posts New Posts RSS Feed: Breaker Switches won’t reset
Topic ClosedBreaker Switches won’t reset
joe12willy View Drop Down
Direct Link To This Post Topic: Breaker Switches won’t reset
    Posted: 18 May 2021 at 7:24pm
172 plugged in but outlets not working. Breaker switch (Conv/Gene/Refer) and (GFCI)/won’t reset. How do I reset these breaker switches? Cause?
Direct Link To This Post Posted: 18 May 2021 at 8:26pm
Normally you simply turn (flip) the switch all the way to the off position and then turn back to on.  If they won't re-set after that than it would appear the breaker switches are toast.  I have had one GFCI in my house do that, a Wadsworth, wouldn't re-set, so purchased a new one-problem solved.
Direct Link To This Post Posted: 19 May 2021 at 6:02am
Could be a bad breaker but it's more likely the breaker is just doing its job and there's a fault somewhere. It's highly unlikely that both the gfci and a breaker would go bad at hr same time.
Disconnect everything you have connected to your receptacles and see if that clears it. If not then you'll need to starts hunting for what's causing it. One commonly reported problem is excess moisture in the trailer getting into the receptacles. High humidity/rain can do that. You can try taking the covers off the receptacles, look and see if you see moisture or signs of shorting inside.
Direct Link To This Post Posted: 19 May 2021 at 7:20am
+1  Didn't consider that OG as that is usually not an issue in the north country but obviously is in most other parts of our land.
Direct Link To This Post Posted: 28 May 2021 at 7:53pm
Thanks for the replies. We reset all the breakers and that seems to have solved the problem.
