Tonii87
Topic: No water in bathroom sink faucet Posted: 14 Sep 2021 at 10:29pm |
Good evening,
I recently bought a 2016 R Pod 183g. I was making sure all the plumbing was in working order and when I got to the bathroom sink faucet no water was coming out. The water pump would just turn on and off just cycling on and off without any water coming out both the hot and cold water. Any advice or help would be greatly appreciated.
Ciberpine
Posted: 14 Sep 2021 at 11:57pm |
Hate to ask the obvious, but you have made sure that there is water in the fresh water tank? Also, does the sink work when the unit is hooked up to hose water?
Scott and Noreen
2017 R-Pod 190, 2011 Toyota Tundra
Pilgrims on the way to the Celestial City
Tonii87
Posted: 15 Sep 2021 at 12:18am |
Originally posted by Ciberpine
Hate to ask the obvious, but you have made sure that there is water in the fresh water tank? Also, does the sink work when the unit is hooked up to hose water? |
yes I filled the fresh water tank. Kitchen sink worked, shower worked and the toilet also worked no issues there the only problem happened with the bathroom sink.
Posted: 15 Sep 2021 at 6:39am |
Check to see if there is a screen (similar to what you have in the kitchen sink) that could be plugged with debris.
Leo B
Posted: 15 Sep 2021 at 7:46am |
Ditto on checking the screen. I have had that happen to our 179.
Tonii87
Posted: 15 Sep 2021 at 7:54am |
Will check the screen. Thank you
