Lagun style table - source for new table top? |
cormacpara
Newbie Joined: 21 Oct 2021 Location: California Online Status: Offline Posts: 1 |
Post Options
Quote Reply
Topic: Lagun style table - source for new table top? Posted: 21 Oct 2021 at 12:47pm |
Hey podders! I just installed a lagun style table - Will add in some pics (Obviously had to re-enforce) all the backing but I'm looking for a source for the replacement (just shy) of 28" x 28" table top. I came across the "Lama-Light" type stuff but that specific vendor is 2 months out. Does anyone have any suggestions for other vendors and have recieved some lightweight table tops?
Many thanks!
Pod People
Senior Member Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1066 |
Post Options Quote Reply Posted: 21 Oct 2021 at 5:19pm |
I made our tabletop using 3/4' birch plywood cut to size and finished with 3 coats of tabletop varnish. It has served us well for over 4 years. if it ever needed it, it would be easy to sand it and add more coats of finish. it is much larger than your size, but the process is the same. I roughly measured the table size on the blank plywood. Then I added 2" painter's tape to both sides of the plywood where the cuts would be. then I carefully measured the exact size and shape that I wanted onto the taped plywood. make sure all marks on the tape on both sides.The tape will keep all edges smooth when you use your jig saw to make the cuts. the best jig saw blade for this is a down cut, flush cut high tooth per inch blade.After you cut, remove the tape, sand the edges and top and began applying finish. I used Woodwoker's Supply Tabletop Varnish. I have used it before and it makes a smooth, durable finish. You can brush it over bare wood or stained wood. I used 3 coats and steel wool between coats. actually, after we made it and used it a couple of times, we decided to change the size-we made it narrower and shorter and increased the radius of the corners. We did the same process with tape, cut and finish the edges. Travel Safe Vann
Toyanvil
Senior Member Joined: 15 Feb 2019 Location: Bakersfield Online Status: Offline Posts: 157 |
Post Options Quote Reply Posted: 21 Oct 2021 at 9:44pm |
I used my stock top so I can still set up the bed if needed.
Here is the mount I made. |
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 343 |
Post Options Quote Reply Posted: 22 Oct 2021 at 7:38am |
Good job, clean and stout. Did you do the fabrication?
Jay
179/2019 |
Toyanvil
Post Options Quote Reply Posted: 22 Oct 2021 at 10:35pm |
Thank you, yes.
