  New Posts New Posts RSS Feed: Jensen Stereo System making noise
richardd View Drop Down
Post Options Post Options   Quote richardd Quote  Post ReplyReply Direct Link To This Post Topic: Jensen Stereo System making noise
    Posted: 20 Apr 2022 at 4:07pm
My Jensen Bluetooth Stereo system keeps making buzzing sounds, when it's off. I never use it, but maybe I should keep it installed in case I want to sell the camper. Anybody know what that is, or how to disconnect the thing?
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2022 at 8:36pm
Take the four screws out that hold it in place and all the connections are on the back. Remember what is supposed to connect where (picture helps) and then if you want to reconnect it, you will know how.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2022 at 3:06am
I replaced mine for the new owner when I sold the trailer last year. I wasn't using it either and all it was doing was making static too. Tried the usual contact cleaning procedures, no joy.
Most electronic and mechanical devices last longer if they are used. If left off internal corrosion tends to set in.
Jensen (for now) makes a new model that is a drop in replacement if you need a new one, not cheap. If you do plan on replacing it the longer you wait to buy a new one the less likely that you will be able to find a compatible unit.
