  New Posts New Posts RSS Feed: Soft undercarriage corner
Rpodrrr View Drop Down
Post Options Post Options   Quote Rpodrrr Quote  Post ReplyReply Direct Link To This Post Topic: Soft undercarriage corner
    Posted: 24 May 2022 at 2:54pm
2015 127 RPOD
I was checking the silicone sealing around my RPOD and found a corner had water infiltration. When pushing my fingers up under the the corner (underCarriage) it was found to be soft. I used an oscillating saw to open it up from underneath and found the cheapest thin plywood rotting out. I have traced and tied the actual damage to the way the water runs off the back of the trailer. The manufacturer did not install a drip edge so as to stop the water from curling up under the undercarriage and getting through the plastic barrier and into the floor. I have since installed a drip edge along the back of the trailer and siliconed it so water drops off lower that the flooring. I used aluminum carpet transition as a flashing.
I also used corrugated plastic with construction glue to replace and rotted undercarriage and then used Gorilla waterproof tape to seal it all in. thought I would pass the tip along to other members to add a drip edge to avoid this problem of water running down the back of the trailer then curling in under and wetting things out.
Post Options Post Options   Quote Rpodrrr Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2022 at 3:04pm
saltboy View Drop Down
Post Options Post Options   Quote saltboy Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 4:47pm
I too found that my 180 had water getting in along the back edge as it was not a complete seal with the floor covering on the underside. I ran a wide bead of rubber roof lap sealer that seems to also acts as a drip edge. I had my R-Pod since the fall of 2020 the poor craftsmanship has led to me redoing over 15+ items
