  New Posts New Posts RSS Feed: Solar not charging and battery depletion
Gregs Pod View Drop Down
Post Options Post Options   Quote Gregs Pod Quote  Post ReplyReply Direct Link To This Post Topic: Solar not charging and battery depletion
    Posted: 28 Aug 2022 at 1:16pm
I have a 2019 rpod 191 that was pre-wired for solar. Had the dealer install GoPower 220 flex panel kit that comes with GP30 controller. It has never worked right. now batteries discharge daily. GoPower replaced controller under warranty but charging amps still below 1, even in full sun with boost. Dealer rewired as wrong gage extensions had been used. Field tech has tested panel output and its fine. Any suggestions appreciated.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 4:13pm
How did the tech test the solar modules? You can't just check the open circuit voltage and the short circuit current of a solar module and call it good. If your having a problem then you should place the module(s) under load.
To do that you can connect the solar modules directly to a 12V battery without the controller. This wont harm the battery by overcharging it if you only do it for a short time
You'll probably have to buy a sect of MC connectors so you can connect the modules to the battery.
Once connected, on a clear sunny day record the battery voltage and the charging current. The current should be in the range of 4 or 5 amps or so from each module and 8 to 10A from the two modules combined in parallel.
If you get that then the modules are good and you can focus on wiring or controller issues.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 4:18pm
Another alternative is to ditch the MC connectors and use PowerPole connectors. That is what I did. The PowerPole connectors are much easier to disconnect and connect, and can be done repeatedly without special tools.
Post Options Post Options   Quote Gregs Pod Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 4:24pm
Thanks Off Grid. Tech did not test under load just at wires disconnected from through roof plate as indicated by Go Power. Controller was just replaced but same GoPower model....I have spare 12 v batteries from our off grid cabin and boats so that may be my next step without having to remove the trailer batteries...
Post Options Post Options   Quote Gregs Pod Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 4:25pm
Thank you, I'll take a look at those
