battery, converter issues |
ace
Newbie Joined: 26 Jul 2020 Online Status: Offline Posts: 9 |
Post Options
Quote Reply
Topic: battery, converter issues Posted: 19 Aug 2023 at 1:03pm |
Rpod 2014 182G
Replaced the converter and the green light is on. When Im hooked up to house power and battery the lights work. When I unhook the battery lights do not work. Also I do not hear the converter fan. ???
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 345 |
Post Options Quote Reply Posted: 19 Aug 2023 at 4:12pm |
I believe that the converter is wired directly to the 12v battery(ies). When you are connected to "shore power" and the positive and negative on the battery is connected that is when the converter will be working (and you should hear the fan). The converter will be charging the battery, if it needs charging. For the factory wired lighting in the trailer to work the battery has to be connected so that there is power to the trailer's lights, which are all 12v. That is the same for the jack on the front of the trailer and the motor's for the slide out if the trailer is so equipped. There are some other items in the trailer that require 12 voltage to work and require the battery to be connected. Hope this helps.
Jay
179/2019 |
