Manual Tounge Jack to Electric |
rpodski ![]() Newbie ![]() Joined: 09 Jun 2023 Online Status: Offline Posts: 1 |
![]() ![]() ![]() ![]() Posted: 09 Jul 2024 at 7:57pm |
I followed a topic "Electric Tongue Jack....??" It closed and I could not post to it... I want to change to Tongue Jack to Electric on mine, but I have no clue The previous topic indicated a 4500lb works good In researching they say: You will want to get a jack that has a capacity of 10-15% of your campers weight R pod specs indicate Hitch Weight 359 lbs Dry Weight 3447 lbs So, figure loaded, 4000 – 4500 lbs 15% of 4500 = 675 lbs that's no where near 4500 lbs Can someone straighten me out there must be a formula to follow? Thank you Trailer Details Rp 180, 2016 S/N 4X4TRPT19Gl015048 |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6322 |
I used this one with our 179 and had no issues with it that were not caused by me. Remember, you are not lifting the whole trailer, just part of the weight and part of the tow vehicle weight if you are raising the hitch to help get bars on. This one had plenty of capacity with the 179. Edit: The bubble level on it is next to useless. Also, it lost whatever liquid was in it after a couple of years. Other than that and me accidentally bending the bottom which I fixed by sawing off a little and drilling a new hole for foot attachment, it functioned without issue.
Edited by StephenH - 09 Jul 2024 at 10:10pm |
