  New Posts New Posts RSS Feed: Bathroom outlet
Bathroom outlet
4ster View Drop Down
Post Options Post Options   Quote 4ster Quote  Post ReplyReply Direct Link To This Post Topic: Bathroom outlet
    Posted: 30 Sep 2024 at 3:29pm
Just bought 2024 192 rpod and figuring out how everything works.  I noticed that when I have no power connected to pod and battery disconnect is turned off the bathroom outlet still has power. Is this normal?
Kevin
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 11:17am
Off hand, I can’t see how that can happen. You either need to have shore power hooked up or a bank hooked to an inverter.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
James07 View Drop Down
Post Options Post Options   Quote James07 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 1:40pm
Inverter charges the battery and the battery powers the bathroom lights.  All outlets are 110v, so no power when shore power is not connected.  So if you are saying the bathroom light is on, that might mean your battery disconnect is malfunctioning and battery power is still getting thru.
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 7:16pm
Just to keep terminology accurate, the converter/charger charges the batteries and converts 110v to 12v when connected to shore power. When connected, everything 12v and 110v should work. When not connected, anything 12v will work as long as the battery is charged. 110v outlets will not work.
If an inverter is installed and connected to the battery(s) and has a transfer switch, then everything 12v and 110v should work with the exception of the AC.
Gpokluda
2022 Escape 5.0TA
Kawasaki KLR650
