Electric and gas usage only - Event Date: 18 Aug 2011 - 30 Sep 2011 |
HZNHRZ
Newbie Joined: 09 Mar 2011 Location: United States Online Status: Offline Posts: 17 |
Calendar Event: Electric and gas usage only Posted: 18 Aug 2011 at 5:11am |
Would like to use either a generator or plugin using a dryer vent at home(Is this possible, by the way). I would like to use the furnace if necessary. One of my questions: If I am not using a water hookup if I use the the furnace will the hot water heater burn out? I have not winterized yet and I am not sure if I need to switch off the water heater. If so where is the switch located?
Also, will my car battery have enough power to sustain the camper battery to run the refrigerator, tv and 1 light for a night without a generator? Secondly will it support the furnace as it burns propane?
Guests
Guest Group |
Posted: 18 Aug 2011 at 7:34am |
**Technically, this is 2 120v. +or - AC "legs", out of phase with each other.
pentachris
Groupie Joined: 02 Aug 2010 Location: Montgomery, AL Online Status: Offline Posts: 40 |
Posted: 18 Aug 2011 at 11:10am |
I think David answered the questions pretty well. I'd make three amendments.
First, just to clarify, the furnace and the water heater have nothing to do with each other, except for the fact that they both warm things up. They are separate systems. Second, there are two water heater switches. David correctly identified the first one but only implied the second one. The one that switches the propane functionality is inside. On mine, it's either on or right beside the control panel that I use to look at the levels of my water tanks and the charge level of my battery. Third, the TV runs on AC, not DC. So, unless you've installed an inverter, you will not be able to watch it with battery power alone; you need to be plugged into shore power.
HZNHRZ
Posted: 18 Aug 2011 at 12:40pm |
Thanks for the advice.
Posted: 18 Aug 2011 at 1:40pm |
I will not lie... a competent electrical hack *could* make an adapter to plug their Airst.. er.. a travel trailer or other 120/30A device into a dryer plug. I am SURE info about it can be found on the internet...
They then would, of course, at some later date, add a proper 120v 30A travel trailer connection in the garage. |
Posted: 18 Aug 2011 at 4:45pm |
Much easier to just use a 30-to-15 amp adapter and plug your 'pod into a standard home outlet in your garage.
Even with no water hookup or water in your fresh water tank you can safely run the water heater as long as there is water in it. You just won't be able to get any of the hot water out of it until you hook up a city water connection or fill the fresh water tank and turn on the water pump. To be safe, keep your water heater filled with water during the camping season - then you won't risk burning out the electric element (or causing problems by running the propane burner) on an empty tank.
The 12 volt mode of the fridge uses 120 watts-hour (10 amps-hour). A standard deep cycle battery is rated for 100 amps @ 20 hours, which means you should only use at most 70 amps, and normally only 50 amps, using a load that will last exactly 20 hours. However, your fridge will use much more than this. So while you might think you can get 7 hours of run time in reality you will only get about 4 before you start taking too much out of the battery. If you tried to run it for 8 or 10 hours overnight you would have a permanently damaged battery by morning.
Guests
Guest Group |
Posted: 18 Aug 2011 at 5:12pm |
Thanks to you and Tech for filling the gaps. Another thing I forgot to mention would be to run the fridge on propane. As Tech suggests, running it on 12v. would not be good. It still uses some 12v. power to control the "brains" of the fridge, but it is minimal. I don't know why I am thinking this but, don't the newer Pods have 12v. TV's? I seem to recall seeing in some pictures that they have a Jensen DVD/stereo like mine - which is 12v.
cgarb
Groupie Joined: 27 Mar 2011 Location: California Online Status: Offline Posts: 95 |
Posted: 28 Sep 2011 at 1:56pm |
Our new HR 177 TV/DVD player only work with shore power, as do the microwave and AC.
Carol
177 HRE rpod 2014 Honda Pilot |
Goose
Posted: 28 Sep 2011 at 2:17pm |
If you want to run the POD on 120 volts at home and you have an outside 120 volt receptical just pick up a "dog bone"... it is a short cord that one end plugs into your 30 amp shore power cord and the other end plugs into your 120 volt receptical that is 20 amps. That's what I do at home, it will keep your battery charged and you can run anything you want in the POD. I have run the air and the frig and don't have any issues. Goose
