It's so easy and takes so little time, you'd be risking a bunch not to do it each time. Also, keep in mind, you will get to a point in the winter season where you will not be able to properly/safely use all the water related items while camping. What I mean is, if it's only dipping below freezing for an hour or so at night then getting above freezing during the day, you should be fine all around. Once it starts to stay below freezing longer and does not break freezing temperatures during the day, you'll need to stay winterized with antifreeze throughout all lines. You won't have running water inside or will you have use of the hot water heater. You will be able to use the toilet by flushing by dumping a pale of water down to flush, but make sure you have a couple gallons of antifreeze dumped in your holding tank.
