  New Posts New Posts RSS Feed: Raer Hitch 182G
Topic ClosedRaer Hitch 182G
John & Kris View Drop Down
Direct Link To This Post Topic: Raer Hitch 182G
    Posted: 15 Mar 2012 at 8:21am
ConfusedWe have a question. Does anyone know how much the Rear Hitch on the 182G will hold? We are thinking of putting a small rack that could hold a generator and a small gas can.
Or does anyone know whol to contact at FR R.Pod either via e-mail or phone to ask?
Many thanks John
John.Kris & "Sarah" our Golden
Aiken SC
"12 R.Pod 182G
TV "12 Lexus GX460
tpierce220 View Drop Down
Direct Link To This Post Posted: 15 Mar 2012 at 10:10am
My understanding is that rear hitch was designed to hold bikes, but I don't know if it will support everything you want to put back there.  The only email contact I have is from Susan who works in the warranty area, but she may be able to give you an answer: sthornburg@forestriverinc.com
Tim
TIDALWAVE View Drop Down
Direct Link To This Post Posted: 15 Mar 2012 at 11:05am
A couple of threads from last year discussed how much the rear hitch could tolerate:  a couple of bikes plus the bike rack.  Several owners talked about having a local welding shop install a completely new hitch with a much higher rating.
I remember one owner who found that his Pod hitch was starting to crack even tho' he only hauled a couple of bikes.  I haul my bikes and Pod tire in the rear of my PU.  I don't trust the Pod hitch. Barely able to carry my Pod Tire, if that.
TIDALWAVE
Direct Link To This Post Posted: 15 Mar 2012 at 11:12am
Thanks for the responses. I will try to contact FR: R.Pod people and also take it to a hitch shop for an evaluation. Just thought it would be a great place to store a generator.
John
Aiken SC
"12 R.Pod 182G
TV "12 Lexus GX460
Outbound View Drop Down
Direct Link To This Post Posted: 15 Mar 2012 at 11:33am
About 75 pounds - vertical (not cantilevered).
If you're looking to carry a generator, how about on the tongue? I remember (quite a while ago) someone had the same idea as you and then discovered how little the rear hitch can hold. Instead, they removed their propane tank, mounted a carrier rack directly on the tongue and reinstalled the propane tank on the rack. There was enough room on the rack to carry their generator too.
Direct Link To This Post Posted: 15 Mar 2012 at 3:18pm
Outbound's suggestion would be the better option.  As Tidalwave remembered, you will have to reinforce the pod's rear hitch if you want to apply additional leverage and weight to it.
I suggest that you not permanently mount your generator.  During use you'll want to get it off of the frame (which will transmit vibration into the pod) and as far away as possible to cut down on noise.  I also highly recommend the Yamaha and Honda inverter-generators since they are very gas-efficient and quiet, but some of the smaller models will not run the pod's A/C or microwave.
Direct Link To This Post Posted: 15 Mar 2012 at 5:41pm
Thanks Doug We have had Honds in te past but am leaning more towrsd the Yamaha in the futur...perhaps if we get a truck put it in the bed.
Thanks for the the ieads and help.
John
Aiken SC
"12 R.Pod 182G
TV "12 Lexus GX460
rid415 View Drop Down
Direct Link To This Post Posted: 15 Mar 2012 at 9:10pm
yah thats good plan
Direct Link To This Post Posted: 15 Mar 2012 at 9:11pm
plus the truck holds more
