  New Posts New Posts RSS Feed: Wiring Harness
Topic ClosedWiring Harness
OHIOJJ View Drop Down
Direct Link To This Post Topic: Wiring Harness
    Posted: 24 Apr 2013 at 9:47am
I had to have the connector replaced on my wiring harness.  It is a 7 pin.  Place that replaced it didn't know what to do with the 7th wire.  It appears that my fridge can no longer run off battery power.  Is this due to the 7th wire not being hooked up?
Thanks
Outbound View Drop Down
Direct Link To This Post Posted: 24 Apr 2013 at 12:30pm
Maybe, maybe not. It depends on which you're calling the 'seventh wire'...
This diagram may be of help.
Yes, there is a black charge line in the connector that brings 12v power to your trailer. There is also a yellow reversing lights/aux line that is not used in your trailer; so, if the yellow wire isn't connected, that's perfectly fine as it isn't used anyway.
In either case, if your battery is charged, your fridge should operate on 12v. Even in the trailer isn't connected to your vehicle. If your fridge isn't working on 12v, then its time to check your battery and fuses to make sure there isn't a problem.
Direct Link To This Post Posted: 24 Apr 2013 at 3:02pm
+1
Direct Link To This Post Posted: 24 Apr 2013 at 6:40pm
Big smile  Thanks for the help!!
