electrical question |
Pod People
Topic: electrical question Posted: 01 Jun 2013 at 3:31pm |
We just got our new(to us, 26000 miles) tow vehicle-a 2012 Ford Expedition.
We moved the brake controller and 7 pin female connector from our old vehicle to the new one. We used the same brake controller and the same 7 pin female connector that we took off of the old tow vehicle(Chevy Astro). All of the brake. turn signals and running lights seem to work fine. However, none of the pod interior lights or anything else 12 volt will not work off of the Expedition battery when the Pod battery is turned off. the pod will not work whether the Expedition engine is off or on. There is a clicking sound like the power center is tripping a breaker or resetting. But nothing seems to be tripped. when I unplug the 7 pin connector, the pod works fine on it's own battery power. I am concerned because 1) we can't use the battery powered emergency braking system on the hitch unit which must be powered by the Pod battery 2)we can't run the refrigerator off of the tow vehicle while driving 3)I wonder if the tow vehicle is recharging the Pod's battery while driving?? I am almost positive that the Pod would run off of the battery in the tow vehicle before. I think we should be able to run the lights, refrigerator and other l12 volt equipment off of the tow vehicle battery power. Is this correct?? Any thoughts or help would be appreciated. Thanks Vann |
TerryM
Posted: 01 Jun 2013 at 4:10pm |
Either go to a RV dealer or a Ford dealer. Chevy and Ford don't match in the wiring.
Terry |
Outbound
Posted: 01 Jun 2013 at 4:27pm |
The clicking sound /could/ be a relay. Or, the clicking sound could be a self-reseting fuse shorting out. On the other hand, you may simply have a burnt out (or missing) fuse somewhere. Regardless, it sounds like its time to get out a multimeter and trace wires.
CharlieM
Posted: 01 Jun 2013 at 5:18pm |
A simple check to see if the tow vehicle (TV) is charging the camper. I use an inexpensive battery condition (volt) meter plugged into a 12V socket inside the camper, but a digital voltmeter connected anywhere on the trailer 12 volt system will do. With the TV turned off and the trailer unplugged from shore power the battery should read around 12-12.5 volts. With the TV connected and running the trailer battery should read around 13.6 volts or slightly higher. The higher voltage indicated the TV is charging the camper battery. Clicking sounds probably indicate a loose or miswired connection and needs to be fixed.
Anthony Valenzano
Groupie Joined: 09 Apr 2013 Location: Archbald Pa Online Status: Offline Posts: 44 |
Posted: 01 Jun 2013 at 9:44pm |
You may have to install a fuse or two in some hidden place to connect the constant power to the trailer.
Posted: 01 Jun 2013 at 9:45pm |
I'm leaning towards self-resetting breaker like Outbound said. I'd bet nothing is working because you have the +12 and ground reversed, and the converter is protecting itself with an anti-polarity breaker.
Pod People
Posted: 02 Jun 2013 at 9:46pm |
I posted the same question on the Ford Expedition forum. apparently, I
need a relay and a fuse to make everything work properly. These parts
apparently come with the heavy duty tow package but not the standard
units.
so, I'm off to my local Ford dealer in search of the appropriate relay and fuse. I'll follow up after the problem is fixed. thanks for the info. Vann |
