  New Posts New Posts RSS Feed: Low Gas Flow
Topic ClosedLow Gas Flow
dsmiths View Drop Down
Direct Link To This Post Topic: Low Gas Flow
    Posted: 24 Feb 2014 at 8:50pm
Since day one I have had trouble with running gas appliances. I had to turn the gas on 4 to 6 hours before use and then sometimes the furnace (which we rarely use due to noise) would thump and go out. gas stove burners would run for 1 to 3 minutes and go out. anyway the problem was the factory flow restrictor, you know that green collared thing that screws right into the tank. The factory hose/restrictor valve would only function until the tank got about 1/2 empty then you were done. I replaced the flow restrictor and cured the problem. I replaced the tank, the regulator and of course it was the last thing I replaced. Looking forward to turning on the gas valve and using the equipment right away instead of waiting a half of a day. Come on Mr Spring.
Dane and Donna Smith
2011 RP-172
lift kit
Robwid View Drop Down
Direct Link To This Post Posted: 24 Feb 2014 at 9:53pm
We had a similar problem.  It would take forever to get gas flowing at the stove which was always our first step before turning on appliances.  Our dealer replaced the regulator under warranty.
Rob
2012 HRE 177
2010 Toyota Tacoma
Direct Link To This Post Posted: 25 Feb 2014 at 8:05am
Many of the earlier pods had a problem with the regulator "pinging" while under high load.  That was annoying.  Furnace would kick on and you would think you were in The Hunt for Red October.
Direct Link To This Post Posted: 01 Mar 2014 at 8:54am
That fixed it. the knurled nut that screws into the L.P. Tank has a flow restrictor for safety. I put a new restrictor and line on , turned the gas on, went inside and lit both burners on the stove they worked perfectly. before they would had lit and then the flames would have shrunk and went out in about 5 to 10 seconds, then you would have to shut off burners and wait. Sometimes this would take 2 hours and was very frustrating. NO MORE LOW GAS FLOW
2011 RP-172
lift kit
kymooses View Drop Down
Direct Link To This Post Posted: 01 Mar 2014 at 3:40pm
Glad to hear that it's working good now!!
Thumbs Up
Direct Link To This Post Posted: 01 Mar 2014 at 7:18pm
The hottest story of the day.
