Sewer connections on R178 |
Post Reply | Page <123 |
CharlieM
Topic: Sewer connections on R178 Posted: 14 Mar 2014 at 9:33pm |
Doug,
Next time you smell the sewer open the cabinet and stick your nose under the stove/sink. If the breaker is bad it will be immediately obvious |
asreichler
Newbie Joined: 30 Jul 2013 Location: austin tx Online Status: Offline Posts: 35 |
Posted: 15 Mar 2014 at 3:40pm |
has anyone connected the gray to the black with a permanent hard connection under the rig?
Allen |
2014 178 TV 2004 Dodge 2500 deisel
Posted: 15 Mar 2014 at 8:08pm |
Charlie, what does it look like?
CharlieM
Posted: 15 Mar 2014 at 9:23pm |
Doug,
I assume you mean the vacuum breaker/vent. It's a round black object about 2.5" diameter and about the same height. Follow the sink drain pipe from the wall toward the P-trap. The breaker sits atop a tee on this line near the P-trap. You can't tell visually if it's working, but they're cheap so just replace it if suspect. It just unscrews. It's function is to let air into the pipe during draining to prevent a vacuum from sucking the p-trap dry. Dry p-trap equals bad news because sewer gasses can then flow into the camper. The same devices are use in houses when it's too hard/expensive to provide an external vent to a sink. http://www.amazon.com/Plumbing-air-gap-check-vent/dp/B00CYYXING/ref=sr_1_4?ie=UTF8&qid=1394932347&sr=8-4&keywords=rv+sink+vent |
Posted: 15 Mar 2014 at 10:25pm |
You know, I saw that weird pipe when doing my outside shower mod, wondered what the heck it was, and meant to go back and investigate.Thanks for the heads up!
Posted: 15 Mar 2014 at 11:15pm |
Ah, we had one of those installed when we had a utility sink moved to a new location. Looks different than the one in the link but same thing.
marwayne
Posted: 15 Mar 2014 at 11:19pm |
In the 172 it is high up behind the cooktop.
