techntrek ![]() Admin Group - pHp ![]() ![]() Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9059 |
![]() Posted: 02 Apr 2014 at 10:03pm |
A month ago I posted about the multi-function gauge I purchased, mostly to keep track of true coolant temps, oil temps, and torque converter slip while towing. Last week I had a large secondary transmission cooler installed, in addition to the secondary cooler from the factory as part of the heavy-duty towing package. Last summer I ran very warm due to the cargo tray and generator in front of the truck and this should take care of that problem. From everything I've read you can't cool a tranny too much, with the exception of initial startup with temps well below freezing. So far I've seen the temps stabilize 40-50 degrees cooler than it did before so it is a good start. I also swapped out the all-terrain tires with low rolling resistance tires to help improve mpgs. The all-terrains are great in the snow so I'll swap them back next December. So far I've seen a 6% improvement but I've been a bit heavy on the throttle so I expect more. |
