12 volt light |
Topic: 12 volt light Posted: 20 Oct 2014 at 11:18am |
Yes, you could do that. You may want to convert those fixtures to LED lights (which use 1/10 of the amps that the incandescents use) to be sure you don't blow a fuse.
lumilew
Newbie Joined: 02 Jun 2013 Location: northern Illino Online Status: Offline Posts: 21 |
Posted: 20 Oct 2014 at 6:04am |
Can I run a new wire from the closest light to this one? In other words I would splice a new wire to the close 12 volt light and wire this one to that. Otherwise I can't figure how I would trace the wire through the ceiling.
Thanks Luanne. |
Luanne
wildfire305
Groupie Joined: 22 Jul 2014 Location: Erlanger, KY Online Status: Offline Posts: 85 |
Posted: 19 Oct 2014 at 7:36pm |
On the power center where all the fuses are, a light will be lit if you have any blown fuses next to the fuse that is blown. Otherwise you may have to run a new wire or trace the old one and probe it for power at various spots. I have found pinched wires in my unit that hadn't failed, but I unpinched them when I saw them.
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey 2015 RP179 "73b" OLD 2005 Viking Saga 2480ST popup |
lumilew
Posted: 19 Oct 2014 at 7:30pm |
I have lost power to the 12 volt light over the bed in the 178. I bought a new fixture because I broke a clip in the old one while trying to get it to work. The new fixture didn't work so i checked the wires and no power. Could it be a fuse? If so which one? All the other lights work great.
Thanks Luanne |
Luanne
