Power fridge while driving - Event Date: 26 Feb 2016 |
Post Reply | Page <12 |
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Calendar Event: Power fridge while driving Posted: 27 Feb 2016 at 8:51am |
Yes, this is true for all vehicles as far as I know, but since my bargman is not factory installed it was wired for lights only and there was no hot lead run to it, I installed it myself. It was simpler to parallel off the battery and run straight to the plug. I also ran a negative wire since the trailer light harness is very light gauge. Need to risk blowing signal lights fuse |
Posted: 27 Feb 2016 at 9:01pm |
Almost. I ran it from the lug on the fuse block under the hood where the factory wire originates from, back to the existing wire just before it runs into the Bargeman. No reason you couldn't run it from the battery.
Posted: 27 Feb 2016 at 9:02pm |
GM doesn't, unfortunately.
