Deep cycle batteries |
Post Reply | Page <12 |
CharlieM
Topic: Deep cycle batteries Posted: 11 May 2016 at 12:02pm |
If I follow your explanation your battery is probably OK. The reverse polarity fuses are there to protect the converter and they've done their job. You ran the battery down once, which decreased its life, but not killed it. Replace the fuses and let it recharge from the converter for 24 hours and try it again. After disconnecting shore power and letting the battery sit for several hours with no load on it, the voltage should be 12.6-12.7. If so it's probably OK. Repeated discharges or prolonged discharged periods will decrease battery life, but once is not the end. That said, we all recommend dual 6V golfers if you plan to do any off grid camping. It's not at all complicated. |
Happy Tripping
Posted: 14 May 2016 at 9:39am |
My sincere 'thank you' for all of the responses. I frankly admit that I panicked at our imminent trip to Yellowstone in May with no battery.
Being a Klutz (After all, I did misconnect the battery) the thought of the complexity of 2 batteries is daunting. Not the first connection, but repeated connections/disconnections with the trailer, trickle charger, etc. A group 27 battery might be a good first step to improved dry camping for me. We're off the day after tomorrow for 3 weeks, again, thanks to all the responses.
Kantuckid
Newbie Joined: 14 May 2016 Location: KY Online Status: Offline Posts: 38 |
Posted: 14 May 2016 at 1:18pm |
One of the biggest favors you can do for your battery(I'd buy the biggest deep cycle 12v Walmart sells) is to buy one of the better battery tenders. As a motorcycle rider this is a common topic that comes up when storing them. There are several brands but don't make assumptions based on whats familiar. I ruined a pricey trolling motor via a Sears DieHard tender several years back after it cooked my new battery! I use CTEK and Battery Tender for my cycles and farm tractor=bunches of them. There a few others that are also good. Avoid cheapo stuff from Walmart or any other bargain brands, like Harbor Freight-batteries are too expensive to overcharge! You need a smart charging type tender!!!
It's easy to hook up two 12v batteries-google is your friend and all you need is a some heavy cables from a salvage yard (the friendly kind that allows stuff they never sell to go cheap) You'll need to solder or crimp heavy terminal ends after cutting to length for wiring set-up. |
Plantguy
Senior Member Joined: 29 Mar 2015 Location: Calistoga, Ca Online Status: Offline Posts: 102 |
Posted: 18 May 2016 at 8:35pm |
Do you have a duel battery box for the 2batteries? If you do, where did you get it?
Thanks, Ken |
Life is too important to be taken seriously!i
Posted: 17 Jun 2020 at 8:05am |
This has some good information about marine batteries: Essentially, what you are looking for is a deep cycle battery, regardless whether it is labeled marine or not. For that, you would need to look at the rating, specifically, the 20 hour rating. This site has a lot of information about batteries. It is worth the time it takes to wade through it. It will answer a lot of questions (and probably provoke a few more). My take is that LiFePO4 batteries, while expensive are not as bad a deal as they used to be since the price has come down. Up front they are more expensive than flooded, AGM, or Gel batteries and require other modifications such as replacing the converter and possibly adding a DC to DC charger for charging while towing if a lot of time is going to be spent on the road. However, their 3,000+ charge/discharge cycles mean they should last for many years in use. That is what I did. You can see it in my mods.
Colt
Posted: 17 Jun 2020 at 2:21pm |
Ask for a trolling motor (deep-cycle) battery.
John
'16 R-Pod 180 |
