Pea Pod
Calendar Event: both water faucets Posted: 18 May 2016 at 2:17pm |
HELP......Both faucets dribble after using water pump. It can take up to ten minutes for the dribbling to stop !!! What gives ?? Only our second trip out in new 2016 179.
Pea Pod
Posted: 18 May 2016 at 2:30pm |
That is AFTER pump is turned off, and, NO, not on city water hook up.
Mountainrev
Posted: 18 May 2016 at 2:43pm |
Try cleaning out the screen. It may have construction debris which is causing it to drip. Most Pod owners who have had debris accumulate in the screen have had the opposite effect--water doesn't come out (or very little does). But it's conceivable that the debris is trapping water that just drips until there's none left.
2014 177
Leo B
Posted: 18 May 2016 at 3:44pm |
I agree with Mountainrev the debris can cause all kinds of problems.
Pea Pod
Posted: 20 May 2016 at 12:07am |
Thanks, but there can't be a whole gallon trapped in the faucet !! Is there a such thing as over pressurized tank ?Bath sink leaks after pump is shut off too.
Podster
Posted: 20 May 2016 at 12:25am |
Maybe the water remaining in the neck of the faucet is draining after shut-off because you are not level?
Cliff & Raelynn
Ranger 4.0/178
CharlieM
Posted: 20 May 2016 at 8:03am |
| I'm a bit confused. Are you saying you turn on a faucet and the pump, then turn the pump off but leave the faucet open? You should turn the faucets off after using. Turning the pump off or leaving it on should have no effect. I don't see any way for all faucets to leak if they're all off, no matter how high the pressure is. You would blow a coupling or hose before all faucets would leak.
