WillThrill
Topic: Battery recommendations Posted: 11 Jul 2016 at 5:55pm |
Originally posted by dr.becky
Yes, fridge is on propane. I wish that was the problem. Costco has 6 volt batteries so I am going to get two of those. We have a generator and run it when using the oven and when the battery was low.
Remember that you don't want to let the batteries get below 50% charge or else you'll really reduce their lifespan. There are many ways to do this, but getting a $10 voltmeter and manually checking the voltage is the simplest. If the voltage is at 12.2 or below, you need to recharge the batteries by running your generator or recharging them from some other means.
2014 Hood River 177
2005 GMC Envoy XL
SuperDudeAbides
Posted: 10 Aug 2016 at 3:07pm |
Has anyone ever done 4 6v deep cycles? To replicate a dual 12v battery setup? I am planning on adding solar to my pod and in the fall and spring when no AC is required do some boondocking on battery and propane. I had considered doing this but have not personally seen or done it. I do have dual 12V batteries with a kill switch set up in my boat. Just wondering if anyone has used this option (4 6V batteries in series / parallel) . Thanks!
Posted: 10 Aug 2016 at 4:38pm |
Originally posted by SuperDudeAbides
Has anyone ever done 4 6v deep cycles? To replicate a dual 12v battery setup? I am planning on adding solar to my pod and in the fall and spring when no AC is required do some boondocking on battery and propane. I had considered doing this but have not personally seen or done it. I do have dual 12V batteries with a kill switch set up in my boat. Just wondering if anyone has used this option (4 6V batteries in series / parallel) . Thanks! |
Where would you put them, and how long do you want to stay off grid anyways? We did 12 days on our dual 12v's.. figure we could do close to 20 on our dual 6v's, if the weather is right. If you have solar to recharge the batteries, even if it's not a full charge everyday, you can stay out an awfully long time.. We try to do a lot of spring/fall trips.
JHoffman
Posted: 10 Aug 2016 at 6:25pm |
Batteries are heavy, four would be close to the 200 lb mark or more. That's a lot of extra weight on the trailer and toung weight on the TV.
2016 176t Rpod the "Hoffpod"
2010 Toyota Tundra 5.7L
Shelpod
Posted: 10 Aug 2016 at 7:15pm |
Invest in some solar panels and two deep cycle 6 volt batteries. We were recently out boondocking with our pod for 5 days and still had 90% on our batteries when we left the site. Even watched some movies at night. 4 bats would be too heavy and hard to mount.
Pod: 2013 178
TV: 2014 Explorer Limited with tow package
Mojave1
Posted: 10 Aug 2016 at 7:32pm |
12 volt battery groups to choose from are (smaller to larger) 24, 27, 29, & 31. For a single battery setup, eventually, I was thinking I'd go with a group 29 (about $100 at Walmart). Previous trailer had two group 24s. Never ran out of power dry camping, but I hated replacing them every 4-5 years due to cost.
This is an older post... Not disagreeing with anything previously said. Just wanted to attach other options in case someone looked it up.
SuperDudeAbides
Posted: 11 Aug 2016 at 8:40am |
Awesome thanks. My only experience with deep cycle batteries is on my boat, and with stereo playing and what not I have used up a reasonable amount of battery power. I'll probably just stick with the 2 deep cycles and solar and see how it goes.
