Water pump problem - Event Date: 24 Jul 2016 - 24 Aug 2016 |
Timahoy
Newbie Joined: 24 Jul 2016 Location: California Online Status: Offline Posts: 3 |
Calendar Event: Water pump problem Posted: 24 Jul 2016 at 2:30pm |
I have a 2016 RP177 (out of warranty) and my water pump cycles when the faucet is off and there is hot water bleeding into the cold water line also when we hook up to city water it seeps into my fresh water tank.
What I have researched on line and on the Shurflo website seams to point to the diaphragm and valves in the water pump. Has anyone experienced this and what did you find to fix it? Thanks,
Tim & Karen
2016 Rp177 2013 Jeep Wrangler Sport Unlimited |
WillThrill
Senior Member Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |
Posted: 24 Jul 2016 at 3:01pm |
It sounds like the bypass valve is open. It is placed in this position when the Pod is winterized and should be closed for normal operation, with all of the other valves open.
2014 Hood River 177 2005 GMC Envoy XL |
Timahoy
Posted: 24 Jul 2016 at 3:14pm |
Thanks WillThrill I have double checked that and the valve is closed so it has to be something else...Help..
Tim & Karen
Posted: 24 Jul 2016 at 4:16pm |
There was a recent thread that described a problem that sounds like yours. It turns out that there was a check valve on the water pump that was stuck (city water leaking into the water tank was the symptom). The solution described was to disconnect city water and run the pump to try to clear whatever is blocking the check valve. It would not hurt to clean the filter for the water pump either.
